Old 27-12-09, 05:12 PM   #1
steveg
steveg's Avatar
Default worn front brake pads
Hi All
Have some front brake pads on order , as I had some time today , cleaned calipers up all fine and move great . n obinding can spin wheels 3-4 times when on stand.
Have noticed that pads are pretty low approx 1mm left and that after a ride the disks are slightly warm , not burning just tepid
Do worn pads pass more heat to disk ?
Cheers Steve
ex - red sv650s 06 reg
Now Triumph sprint 1050 ABS 05 Reg
AKA Papa Smurf
steveg is offline   Reply With Quote
Old 27-12-09, 05:25 PM   #2
7755matt
Default Re: worn front brake pads
Cant see why they would do, discs should be at least warm after a run, as far as i recall pads will have a slight drag on the disc to keep a bit of heat in to help discs dry out.
Old 27-12-09, 05:33 PM   #3
steveg
steveg's Avatar
It could well be normal , to be honest don't normally feel disk for heat .
Normally tell if there is a problem with binding by how easy the bike can be pushed out of garage .
calipers get a clean once a year , might start doing it twice a year before / after winter as only takes a hr.
Cheers Steve
AKA Papa Smurf
Old 28-12-09, 10:26 PM   #4
jacksuzukisv650
sorry ino this has got nothing to do with your brakes but i wonderd how much ur givi box and rack was .
Old 29-12-09, 12:56 AM   #5
MattCollins
Steve, modern brakes are designed to run with the pads lightly contacting the rotors. Slightly warm is normal. If they get too hot to touch then you may have a problem. It sounds like yours are all good.
Old 29-12-09, 10:14 AM   #6
steveg
steveg's Avatar
No worries , box was bought new from wemoto Kappa k35 cost of £50 , just checked and can't see on wemoto now.
Kappa rack bought off ebay for £45
Not pretty but really usefull.
Cheers Steve
AKA Papa Smurf
Old 29-12-09, 10:15 AM   #7
steveg
steveg's Avatar
I recon your right cheers Steve
AKA Papa Smurf
Front brakes, brake pads. metalmonkey SV Talk, Tuning & Tweaking 47 19-11-09 11:06 AM
Front Brake Pads. Biker Biggles Stuff Wanted 0 26-10-07 04:52 PM
Which front brake pads? thor Bikes - Talk & Issues 10 11-09-07 10:55 AM
Front brake pads advice danf1234 SV Talk, Tuning & Tweaking 10 04-07-07 05:06 PM
Front Brake Pads for SV650 21QUEST For Sale - SV's and SV related items 0 18-12-05 05:46 PM
