Old 28-12-09, 07:01 PM   #1
Nick_69
Nick_69's Avatar
Default Scottoiler fitting.
I recently got a Scottoiler vSystem from www.scottoiler.com for my SV650S k9. Now i the only problem i have fitting the thing is, trying to find the vacuam connection on the engine, if anyone could help me by telling me where it is i would be most grateful
thanks nick
Was SV650S K9
Now GSXR 600 K9
Old 28-12-09, 07:30 PM   #2
mattb200
Default Re: Scottoiler
quite easy to locate (well once you know where to look!) - on the throttle bodies there are a couple of 'spigots' with rubber caps. from memory 2 on the rear and 1 on the front.
i took mine from one of the ones on the rear so that i couls still use the other when balancing throttle bodies. Look through the left or right hand side of frame for a small rubber cap, its hard to explain but you should find it ok.
Old 28-12-09, 07:32 PM   #3
mattb200
by the way if you not already decided where to put the resevoir i put mine under the pillion seat attached to the subframe - it's ok except a little bit of a pian to get to when filling up. depending how many mile you do you might decide to put elsewhere.....
Old 28-12-09, 07:33 PM   #4
Ploppy
If I can remember rightly when i helped fit my brothers, the vacuum connections are inside the 'V' if you get my meaning, capped by little rubber nipples (for want of a better word lol)
Look in the centre of the picture and you will see them. HTH
Old 28-12-09, 07:51 PM   #5
Damian
Cool Re: Scottoiler fitting.
that is so funny i was just doing the same thing and found this
http://www.fookstar.com/?q=node/199
I'm fitting mine tomro
Old 28-12-09, 08:55 PM   #6
Ploppy
Default Re: Scottoiler fitting.
Ha yeah that's funny. Google image search was where I pulled that from
Old 28-12-09, 10:05 PM   #7
Nick_69
Nick_69's Avatar
Thanks for the help i was going to put it on the back of the number plant bracket
Was SV650S K9
Now GSXR 600 K9
Old 30-12-09, 07:35 PM   #8
Nick_69
Nick_69's Avatar
All fitted now thanks for everyones help.
Was SV650S K9
Now GSXR 600 K9
Old 30-12-09, 07:40 PM   #9
Damian
good m8,, not done mine yet tomro, did u have any problems &did u have to take any fairing off
Old 31-12-09, 09:02 AM   #10
Nick_69
Nick_69's Avatar
I did have any real problems, i should of taken the fairing off, it would of made my life a lot easier but i didnt and managed to get my hand in a very small gap.
Was SV650S K9
Now GSXR 600 K9
Scottoiler Fitting K9 TheRamJam SV Talk, Tuning & Tweaking 14 09-06-09 05:11 PM
Fitting Scottoiler plowsie SV Talk, Tuning & Tweaking 32 12-06-07 06:42 PM
Fitting a Scottoiler. Grinch SV Talk, Tuning & Tweaking 110 24-01-07 09:21 PM
Fitting a scottoiler Gazza77 SV Talk, Tuning & Tweaking 6 25-04-06 03:52 PM
Fitting a Scottoiler Gazza77 Ancillaries 2 24-04-06 08:13 PM
