Old 03-02-10, 03:32 PM   #1
tiernanobrien
Default GSXR Front end - speedo problem
Hi,
I have a GSXR front end conversion on my bike and so i had to put a Hall Effect gear tooth sensor on it to get my speedo workin again. It's been working grand for the past 6 months but yesterday the speed reading starting jumping all over the place and today it was working fine but then stopped working all together. I checked the sensor and magnets and they are all still tightly fitted. Any ideas as to what the problem is? Loose wiring / water messing everything up?
Thanks for the replies
Tiernan
Old 03-02-10, 04:39 PM   #2
Whitehouse
Default Re: GSXR Front end - speedo problem
Yea id probably say loose connection/water ingress, not sure how but you might be able to check it with a multimeter if youve got one. How have you connected the sensor to the wiring loom?
Old 03-02-10, 04:48 PM   #3
yup. mine done the same... was loose connection, took off and spliced again. never had any more problems.
Old 03-02-10, 05:46 PM   #4
tiernanobrien
yeah sounds like the only explanation. i think its connected with solder but not 100%. ill take the tank off tomorro and have a looksy. hopefully it shouldnt take too long. cheers
GSXR front end speedo svdemon SV Talk, Tuning & Tweaking 0 30-09-09 03:59 PM
speedo problem w/ GSXR front end catchsomesv650 SV Talk, Tuning & Tweaking 4 19-02-09 08:46 PM
Easy way to fix speedo with GSXR front northwind SV Talk, Tuning & Tweaking 40 04-12-08 01:35 PM
GSXR front end speedo work around Lozzo SV Talk, Tuning & Tweaking 32 13-05-08 05:32 PM
For those with GSXR Front ends & USA Speedo andyb SV Talk, Tuning & Tweaking 4 25-09-07 10:57 PM
