Old 14-02-10, 08:18 AM   #1
RobH13
Default Removing immobiliser
Hey Chaps,
Having a few starting issuses again and now that were over the worst hopefully of the weather i want to try and go through the bike ready for spring.
Unfortunately the bike lives outside and had a bit of a beating from the weather. However, i was advised some time ago to remove the Immobiliser, so thats today's challenge.
I'm presuming that i can't just snip the wires and hey ho, so any advice is greatfully appreciated.
Rob.
Old 14-02-10, 02:13 PM   #2
Default Re: Removing immobiliser
Despite the 'advice', unless it doesn't function correctly, why would you want to remove it?
Don't just cut the wires, if you do it will be very effectively immobilised.
Immobilisers, (and alarms that incorporate immobilisers) all work the same way, there will be one or more circuits that are broken and switched by the immobiliser; immobiliser on - switches off. Trace the wires from the unit, in the most common method of fitting they will pass into the bike's loom and you will see where a given wire has been cut and the two ends connected to two wires from the immobiliser unit, reconnect the original wires.
Still, reiterating the above, if you have an electrical fault that you think may be due the immobiliser or, more likely its fitting, disconnect away, if not the 'advice' to remove it is odd, don't you think?
Old 14-02-10, 02:41 PM   #3
sz1
what year sv ???? if you search my post's youll see what a going on i had. what imbo is it ?
Old 14-02-10, 06:25 PM   #4
RobH13
Cheers Guy's,
It's gone to someone who knows what he's doing, top to bottom sort out.
Rob.
Old 14-02-10, 06:51 PM   #5
Teabag
Good idea - the dealer fit CAT1 on mine seems to be pretty poorly fitted with lots of cheap insulating tape falling off of bare wires roughly soldered or just twisted together. When it gets a bit warmer I will rip it our and start again properly otherwise there will be problems in the future.
immobiliser/alarm stanie Bikes - Talk & Issues 12 11-09-08 05:49 PM
Best immobiliser? blueto SV Talk, Tuning & Tweaking 8 04-02-08 07:40 AM
Removing an immobiliser? northwind SV Talk, Tuning & Tweaking 3 15-10-06 01:32 AM
ALARM/IMMOBILISER macdo Pennine Massive 7 08-08-05 02:45 PM
Immobiliser - How much??? branny SV Talk, Tuning & Tweaking 8 29-04-05 07:07 PM
