How long should I take it easy for? It is a BT016 Battlax
200 miles minimum
1 hard progressive ride. I had a pair fitted last spring at work an they were worn in on the 15 mile journey home. Was a bit warmer though I guess.
I just ride gingerly and build up the lean bit by bit, checking the tyre regularly. You can tell a lot from what it feels like, I'm sure heat cycles have something to do with it but I'm happy based on the surface of it myself. I just check to see it looks and feels similar to a normal 'used' tyre (although the surface in general looks a bit tidier than a proper 'used' tyre).
About two laps.......
dont count any miles in the wet btw
Trinity
Just keep it in the air
#9 |
Mileage is not the important factor, a new tyre will be quite shiny and sheer all over the surface, and a used tyre will be dull and will feel, by comparison, quite rough, look at your other tyre, (if it's scrubbed that is), when your new tyre is scrubbed it will look and feel the same.
#10 |
scrubbing in................ | maff | Tyres | 18 | 25-07-08 12:35 PM |
Quick question about scrubbing in tyre | skyline | SV Talk, Tuning & Tweaking | 10 | 23-04-08 01:36 PM |
GSXR front end swap - front tyre profile. | Khewett | SV Talk, Tuning & Tweaking | 12 | 11-05-06 11:24 AM |
Front tyre and can you mix front and back makes? | creamerybutter | Tyres | 9 | 12-05-05 08:38 PM |
Front tyre and can you mix front and back makes? | stick | Bikes - Talk & Issues | 4 | 04-01-70 03:19 PM |
