Old 06-07-10, 09:54 PM   #1
allantheboss
Default New reg-rec, now blowing fuse.
Hello all!
I have a curvy; it has a new new reg/rec which plugs into a different two cables than the factory original reg/rec. It's installed, but now after about 30 seconds of use of the bike, every single time, a fuse (signals fuse, the only 15amp blue on the left column) blows.
Why is this?
Old 06-07-10, 10:14 PM   #2
allantheboss
Default Re: Heeeeelp!
boing
Old 06-07-10, 10:30 PM   #3
rictus01
rictus01's Avatar
So to clarify, you got another reg/rec from a different bike and plugged it into whatever socket you could find rather than wire it into the correct ones
and now you wonder why it's causing a problem......
Old 06-07-10, 10:34 PM   #4
allantheboss
No, this was not from another bike, it was a SV650S K2 specific, brand-new reg/rec, as mentioned before. It came with instruction to plug the cables into a different pair of cables instead of the originals because "it is better this way"
This is what I got from Suzuki, this is what they told me to do. Do you know why the fuses might keep blowing?
Old 06-07-10, 10:40 PM   #5
gruntygiggles
DaffyGingerBint
gruntygiggles's Avatar
Squirrel mentioned something about this before leaving ours earlier. I thought you'd sold that and just had the viffer now.
Fear not though Allan, the right peeps will see this in the morning and give you the help you need
2012 Welsh TT
RIP Hovie baby
Old 06-07-10, 10:45 PM   #6
rictus01
rictus01's Avatar
Saves me answering then.
Old 06-07-10, 10:46 PM   #7
gruntygiggles
DaffyGingerBint
I'm pretty sure you'll have the answer Mark
Never many people online this time of night to help with these things!
2012 Welsh TT
RIP Hovie baby
Old 06-07-10, 10:49 PM   #8
You need to turn the friendliness up a couple of notches rictus
Old 06-07-10, 10:50 PM   #9
rictus01
rictus01's Avatar
why ?
Old 06-07-10, 10:52 PM   #10
To help out allan
Fuse keeps blowing benjyman Bikes - Talk & Issues 10 03-06-09 12:52 PM
fuse keeps blowing bobm SV Talk, Tuning & Tweaking 5 23-10-08 07:57 AM
Ignition Fuse blowing Frogman SV Talk, Tuning & Tweaking 7 16-04-07 05:57 PM
Main fuse keeps blowing JMCHITTOCK SV Talk, Tuning & Tweaking 7 09-09-05 11:17 AM
HELP...keep blowing a fuse jessie SV Talk, Tuning & Tweaking 5 24-03-05 10:01 PM
