Old 22-07-10, 07:36 PM   #1
craigr91
Default no power?
came home from work on my bike everything ok... was just about to go out on the bike and when i turned ignition to 'on' side lights lit, indicators work but do display on speedo, no fuel pump kick in... any ideas
PS. this did happen a few days ago but when i lifted bike up it started working and worked since...
cheers.
Old 22-07-10, 07:44 PM   #2
rictus01
rictus01's Avatar
Default Re: no power?
Oh I love these, give the bearest of information and a covering statement of "everything was ok and it just happened"
so it happened before, have you done the basics ? checked the 3 cutouts ?, checked the fuses, checked the know rub points on the loom ?
might help if you followed the guidelines for asking tech questions and added a complete history/mods/actions taken.
Cheers Mark.
Old 22-07-10, 08:00 PM   #3
craigr91
2004 sk3
Mods: lowers - tailtidy - hugger - front and rear mini indicators.
fuses seem ok...
these cutouts... clutch + side stand + kill switch?
checked sidestand will have a ganders around... not very good at this stuff though..
Old 22-07-10, 08:21 PM   #4
It'll be one of the following (or should be)
- loose connector
- kill switch is 'on'
- side stand cutout is in the 'on' posistion (therefore the bike is in gear) make sure you are in neutral
- battery is on the way out, which sounds v likely from the info given
Old 22-07-10, 08:23 PM   #5
craigr91
been hunting for loose connector.... cant really tell if bike is in neutral as the wholde dash doesnt work =(
anyway of telling if the battery is on its way out?
Old 22-07-10, 08:25 PM   #6
craigr91
ok, bike in neutral (still same) indicator lights on dash work ( neutral light doesnt - main beam doesnt.... so im assuming FI and fuel arnt at this moment).
Old 22-07-10, 08:27 PM   #7
the in gear test is to attempt to move it back and neutral free wheels
you've just partially answered your own question dead dash is 1 symptom. another is difficulty starting and cutting out when the alternator isn't under engine power
Halfrauds will test your battery for free and tell you if its goosed
Old 22-07-10, 08:29 PM   #8
battery me thinks start there and eliminate it.
Loose or corroded connectors. take the bikini fairings off and check every 1, clean up and vasaline them all to avoid a failure
Old 22-07-10, 08:37 PM   #9
fizzwheel
fizzwheel's Avatar
You checked the fuses ?
Old 22-07-10, 08:53 PM   #10
craigr91
3 x 10amp -- 3 x 15amp and 2 x 30 amp right?
Sv power jonhunt SV Talk, Tuning & Tweaking 5 08-04-08 07:52 PM
No Power Willster9 SV Talk, Tuning & Tweaking 5 16-06-07 10:35 PM
Power Commander power graph print outs. JimPSV SV Talk, Tuning & Tweaking 19 27-11-06 09:39 AM
More power aze_b SV Talk, Tuning & Tweaking 23 24-10-06 09:04 PM
Too much power? caines Bikes - Talk & Issues 24 08-04-05 06:09 PM
