Im rebuilding an engine and I'm up to the putting it back together bit. I have been told the timing advice in the Haynes manual is suspect.
Anyone know where I can download the official manual as all the links I found on the Org were dead. Or alternatively can someone post the info from the Suzuki manual? Cheers |
Yep the edition i got from the library was dodgy, its obvious as the marks it tells you are there aren't.
filestube.com search 'sv650 manual' its there ![]() Last edited by beabert; 27-12-10 at 08:10 PM. |
Ok can someone look at the pictue and confirm the timing marks are aligned correctly. These are the REAR cylinder at TDC for the rear, I confirmed TDC for the rear by looking at the timing marks on the front cylinder.
I suspect Im slightly out or its just cause the CCT isnt in. When I move the In cam one tooth back and tighten it up the timing mark 2 is always in this position Thanks for the help |
That is wrong. First you don't set timing on TDC, you set it at F mark. Second intake cam 1R arrow has to be aligned with head.
Sorry set to F (I thought F was TDC)
mmmm my book says 1R alighned to head is front cylinder not rear, I'll have anpther look tomorrow
R is tdc for rear but F is used for cams. That also looks like front intake cam on rear cylinder and why nothing aligns.
#9 |
#10 |
Hard to tell on picture but that looks like A stamped on cam (in middle of cam) which is front intake.
Worst Timing! | Munch | Bikes - Talk & Issues | 2 | 05-10-09 09:11 PM |
Worst Timing! | Munch | Bikes - Talk & Issues | 1 | 05-10-09 08:49 PM |
Lap Timing | Binky | Racing and Paddock Chat | 6 | 19-07-09 10:53 PM |
Engine timing, advice needed please ? | Soprano69 | SV Talk, Tuning & Tweaking | 17 | 21-01-08 09:54 PM |
Timing Issue !!! | SoulKiss | Idle Banter | 1 | 28-06-07 03:58 PM |
