Anyone know what size these are?
Cheers Sent from my iPhone using Tapatalk |
Anyone? Someone must know?
Possibly, yes. I assume you mean the choke plunger, but a fuller description would help.
Yes the choke plunger, theres an o ring that seals it into the carb body.
I need to know what size the o ring is so i can get replacements without having to take the original ones out. Sent from my iPhone using Tapatalk |
I'll see of I can find one to measure - won't be 'til tomorrow evening though.
i just bought some, 9.70 for 2!!! ill go measure in a while
If you find the size it might be worth doing a group buy from Polymax or similar.
If you're spending around £15 it gets much more viable, I had some O-rings for ZX6&10 oil coolers from them, I got 15 of each for the same price as 2 from a Kawa dealer. Viton is ideal for fuel related items though NBR would probably be absolutely fine on the choke plunger. Note that O-rings are specified by the INTERNAL diameter and the material thickness.
"Artificial Intelligence is no match for natural stupidity" Last edited by embee; 17-01-11 at 10:23 PM. |
Dont mention multibuy to me you beast, i havent got over the £9.70 yet. lol
Genuine suzuki is Internal: 9.5mm thickness: 1.5mm Outer diameter 12.5mm |
#9 |
Let us now if you get em cheaper than, £4.85
#10 | |
Cheers for that fella, will let you know if i can get em cheaper, £5-00 for a bit of rubber that costs pennys to manufacture is ****e. Sent from my iPhone using Tapatalk |
O ring vs. X ring drive chains Explained - yet again. | df1uk | SV Talk, Tuning & Tweaking | 19 | 30-04-15 08:15 PM |
What's the stock size of the hole in the carb diaphragm? | TOLAROS | SV Talk, Tuning & Tweaking | 1 | 25-05-10 07:21 PM |
ring size!! | sv650nutter149 | Idle Banter | 37 | 26-11-09 05:54 PM |
Chain and Sprockets & X-ring vs o-ring? | thor | SV Talk, Tuning & Tweaking | 38 | 20-06-09 01:59 PM |
Clutch cover O-ring size | BigBaddad | SV Talk, Tuning & Tweaking | 8 | 23-04-07 11:24 AM |
