Old 28-04-11, 10:57 AM   #1
Steve_God
Question Scottoiler - Dual Injector - Worthwhile? Waste of Money?
Hey peeps,
Finally got round to fitting my Scottoiler a few weeks back with all working fine.
However... now I've done some miles on it and the previous lube on the chain has started to wear off, it seems that one side of the chain is keeping lubed nicely by the Scottoiler, and the other is starting to get dry (The nicely lubed side of the chain matches the side that the dispensor is flowing onto from the back sprocket).
My question:
Is it worthwhile to buy a Dual Injector add-on to cover both sides? Or simply turn the flow of the Scottoiler up so that the oil will spread across to the whole chain? (As I've currently got the flow set to Minimum)
Old 28-04-11, 11:40 AM   #2
danf1234
Default Re: Scottoiler - Dual Injector - Worthwhile? Waste of Money?
I personally had nothing but hassle with it. It would always drain when the bike was packed up, and then air lock. I tried 3 different units from scotoiler and could never get the flow rate right. It would pour out of 1 nib, and hardly even drip out of the other.
I eventually returned them and set it up as single nib and have never looked back.
Old 28-04-11, 12:08 PM   #3
a1istair
I also bought one because I though it was a genious idea... however it was a load of carp!
It seemed like you could never mount it quite right. Riding would always force one of the two nibs to point away from the sprocket. It would always block up and stop putting any oil on, basically as described in the above post. Eventually, maybe with a speed bump or something, the sprocket ate up one of the two nibs and that was that for the dual injector.
I also went back to single nib and once set up well it works fantastically seemingly forever!
a1istair.
Old 28-04-11, 12:29 PM   #4
wyrdness
Wot they said above. Don't waste money on the dual injector.
Old 28-04-11, 12:37 PM   #5
Steve_God
Thanks guys, getting a nice clear picture
Just out of curiousity, what flow level do you have them set at?
I'm thinking that might solve my problem!
Old 28-04-11, 01:34 PM   #6
fizzwheel
fizzwheel's Avatar
Depends on the ambient temperature, basically I turn up the flow till I begin to see fling on the back wheel, then I turn it back down a little bit. Seems to work OK.
I've found theres no set setting that will work on every bike as they all seem to flow a bit differently. In your shoes I'd turn the flow up till the chain is lubed to a level you are happy with and then adjust it from there...
Old 28-04-11, 02:53 PM   #7
Stonesie
Buy a Tutoro duel sided nib for about £4 and use that, they are about as simple as can be and mine has never air-locked or drained itself and it keeps both sides of the chain nice and wet looking.
Sometimes, simple things work better...
Old 28-04-11, 08:23 PM   #8
Steve_God
Just had a look at that on their website - seems a much simplier way to have a twin feed!
Does it join straight into the existing Scottoiler setup or did you have to modify the end pipe to accomodate it? Also, given it's 'pinch' style, are there any issues of it getting pulled in towards the chain by the sprocket?
Old 28-04-11, 08:46 PM   #9
Stonesie
I have the full Tutoro oiler, but it should plug onto the scottoiler pipe although that might need extending.
The pinch pressure on it is next to nothing so once you set it in place it tends to stay put, mine needed a slight adjustment after about 60 miles because the soft plastic pipes ware onto the sprocket a bit, another 1100 miles and it's not moved.
Old 28-04-11, 09:10 PM   #10
That'd be the original single tube that came with the Scotoiler - which works perfectly and is the most robust.
Scotoiler Dual injector - Had enough danf1234 SV Talk, Tuning & Tweaking 8 20-06-10 06:22 PM
Scotoiler Dual injector danf1234 SV Talk, Tuning & Tweaking 12 12-06-10 01:13 AM
Scotoiler Dual injector danf1234 SV Talk, Tuning & Tweaking 4 25-05-10 11:08 PM
Mk7 Scottoiler and dual injector Dodgy For Sale - SV's and SV related items 5 02-11-06 06:15 PM
Scot Oiler Dual Injector RingDing SV Talk, Tuning & Tweaking 17 13-02-06 11:12 AM
