Old 15-05-11, 06:20 PM   #1
jimathyy
Default GSXR eg/rec on SV query.
Could i fit http://cgi.ebay.co.uk/SUZUKI-GSXR600...item27bae61b3f this to my curvy (and will it work)???
Old 15-05-11, 07:35 PM   #2
Default Re: Reg / Rec Queery...
Yes.
Old 15-05-11, 09:54 PM   #3
Default Re: GSXR eg/rec on SV query.
Will need some wiring change though to match connectors, won't plug straight in.
Old 16-05-11, 03:48 AM   #4
jimathyy
how would that work then? Would it just be easier to just get an SV specific rather than having to mess about?
Old 16-05-11, 05:53 AM   #5
mister c
mister c's Avatar
Its a 20 minute job, but if you dont know what you are doing, then yes, buy an SV one.
Old 17-05-11, 11:32 AM   #6
collis
Yes you can fit that, done a similar job on mine. The GSXR one i got is bigger in size than the SV one though and a little cable modding to rejoin the connectors will be required.
They work Much better though, more efficient and are engaged at lower RPMs than the SV unit.
battery/GSXR rear shock query. metalhead19 SV Talk, Tuning & Tweaking 25 30-12-10 08:50 PM
Fitting GSXR front mudguard to GSXR USD forks maviczap SV Talk, Tuning & Tweaking 1 20-02-10 10:05 PM
SV GSXR Fork Swap - Keep Stock GSXR Damper? Mesomorphman SV Talk, Tuning & Tweaking 5 08-09-06 07:40 PM
