Old 16-05-11, 08:10 PM   #1
Dunn-y
Default MOT Failed!
Had my MOT today and it failed because of my rear brake pads. The front pad on the rear caliper was fine but the rear pad had almost worn down to the metal which is why it failed. So i bought some new pads and went to fit them only to find that the front piston has siezed which is why the front pad hadnt worn down much.
Ive taken the caliper off and tried to get it loose but have had no luck. Tomorrow im going to take the caliper to a garage and have them blow it out. However if i can find another caliper cheap i might just go with that. Looks like i wont be getting a free retest as this will probably take longer than 1 day to sort out.
I also got an advisory for an overly tight chain. My chain was adjusted by the mechanic at M&S motorcycles when i had my new tyres fitted and apparently alot of the bikes that come out of thier after having the chain adjusted are too tight. Might be why my gears had gotten clunky and stiff.
If anyone knows of any cheap rear calipers please let me know.
Im in a bit of a rush. Im hoping I can get it sorted before its too late tomorrow which is why I have posted this thread before I go searching through all the other threads for possible answers. Quite frustrated now, but glad I found out about my siezed piston before some bad happened. My own fault for not checking both pads.
Old 16-05-11, 08:14 PM   #2
Wideboy
Evel Knievel
Wideboy's Avatar
Default Re: MOT Failed!
can't help you on the calliper front but it sounds like it needs a rebuild rather than a tart up......... but an advisory for a tight chain?!, who wazzed on that testers cornflakes
05 DRZ400E
RIP hovis
Old 16-05-11, 08:37 PM   #3
husky03
45 delivered ready to fit with your new pads
h.
Old 16-05-11, 09:17 PM   #4
a1istair
Don't you get 10 days to fix stuff and get a free retest??
Old 16-05-11, 09:19 PM   #5
Mate get a refurbed one from Husky alot easier.
Who did the MOT?
Never trust a tyre fitter with a chain. They did one of mine and it had 50mm of play but it depends which guy does it.
is the piston that is siezed the one where the banjo bolt goes. If so M6 50MM and a hammer that how I stripped two rears
Old 16-05-11, 09:25 PM   #6
Dunn-y
Yeah its the side with the Banjo bolt. ill give that a try tomorrow and see what the seals look like. Hopefully it just needs a clean.
Its 10 days for a partial retest but Ive only got till tomorrow evening for it to be free.
My caliper looks in real good condition, no corrosion or anything, just the pistons were a little dirty.
Old 17-05-11, 12:31 PM   #7
sam anon
Can you not re-attach the caliper and pump the stuck piston out?
Old 17-05-11, 02:33 PM   #8
aaron020873
i always thought it was 10 days to have the failed bits re-tested for free?? i would check that out mate cos 1 day doesn't really give you much chance and i suspect they may have been trying to diddle you into getting them to do it for the free re-test. i may be wrong though.
Old 17-05-11, 08:06 PM   #9
dirtydog
Knob faced knobster
dirtydog's Avatar
I've got an mot failure sheet and it says
"If this vehicle is removed from the testing station for repair and returned for retest within 10 working days, then only a partial retest is needed and a partial retest fee may be charged"
And "working days do not include saturdays, sundays or bank holidays"
2011 Speed Triple 1050
Old 17-05-11, 08:21 PM   #10
thefallenangel
If you got a compressor, bleed nipple slackened and shove air up the nipple.
Failed CBT - Twice Littlepeahead Idle Banter 46 12-03-10 07:41 PM
Failed my test nik_nunez Bikes - Talk & Issues 33 12-07-08 09:45 PM
failed again shiver85 Bikes - Talk & Issues 5 17-05-08 12:04 PM
TRE mod failed on 07 vegacr250 SV Talk, Tuning & Tweaking 21 09-07-07 10:28 PM
MOT failed Grinch SV Talk, Tuning & Tweaking 8 26-06-06 06:32 PM
