Old 24-05-11, 07:28 AM   #1
finchy001
Default Fitted new clutch, problem when hot.
Hi everyone,
i stripped the clutch down, soaked the plates in oil and put it all back together as it was jumping in first gear.
problem solved, slips in and out of gear like a dream now.
but...after taking it out for a test ride, the tension in the clutch lever disappears and makes it very difficult for the gears to be moved.
cold its fine, warm its worse than fudge! clutch basket is tighted up, everything is in the right place, and i had no "spares" leftover after putting it all back together.
Anyone got any ideas befoe i admit defeat and let a garage look at it?
Old 24-05-11, 09:52 AM   #2
finchy001
Default Re: Fitted new clutch, problem when hot.
also, to be noted, i have adjusted the push rods as recommended in the haynes manual.
the clutch cable is tensioned correctly, the spring from the clutch slave to the cable is fine, and everything is as it should be as far as i can see.
Like i say, it works when its cold, but once its warmed up, it goes to mush
SV650S comfort kit fitted - clutch cable problem. andycj SV Talk, Tuning & Tweaking 12 07-09-10 09:07 PM
LED Flush mount indicators fitted - problem. Rcollarbone SV Talk, Tuning & Tweaking 19 15-05-10 06:07 PM
Clutch Problem? Cutting off when releasing clutch in first gear! puthsardarade SV Talk, Tuning & Tweaking 15 09-01-08 09:42 PM
new front tyre fitted , problem ? steveg Tyres 3 03-09-07 03:16 PM
clutch problem Roj SV Talk, Tuning & Tweaking 0 01-04-05 08:05 PM
