Old 02-07-11, 09:10 PM   #1
muzikill
muzikill's Avatar
Default sv fuel running costs.
Just filled up today from a brimming tank. Id done 88.8 miles and it cost 8.88 to fill it back up again. 1 quid per ten miles. Dunno if this is good but it got me thinking about how others calculate your fuel costs?
Old 02-07-11, 09:21 PM   #2
Default Re: sv fuel running costs.
depends on how many ltr it took.
mileage / ltr X 4.546 .. gives you MPG
Old 02-07-11, 09:27 PM   #3
over 157.74ltr i have averaged 13.7 MTL so at the current price of £1.309 per ltr it would cost me £0.95 per 10 miles. this is an average over 2160.9 miles
Old 02-07-11, 10:04 PM   #4
The Guru
Its costs me on average 11p per mile
Old 02-07-11, 10:06 PM   #5
muzikill
muzikill's Avatar
I was pretty close. With the bike being off the road for three years it used to cost 11 quid to fill it. Now its around 14. So its a yearly increase of 1 pound per tank fill. Nightmare.
So.... A mile on a sv costs you 10p!
Old 02-07-11, 10:41 PM   #6
mickhew
I check my MPG on every tank. I fill it up, reset the mileometer. Ride until the fuel light flashes, fill it up, and check how many miles I've done. Then divide that, by the amount of fuel I've put in. Nornally 145 miles divided by 2.6 gallons = 55 miles a gallon. My car does 30 mpg, so I use the bike a LOT for commuting. Plus I can easily overtake the people who like to drive at 40mph, in a 60mph limit, that's my favourite bit about my SV.
Old 02-07-11, 10:45 PM   #7
Kirkybhoy
Kirkybhoy's Avatar
I use this site to keep track...
http://www.fuelly.com/
currently 63.7 mpg (£0.96 /mile )
The World Is Full Of Kings & Queens Who Blind Your Eyes & Steal Your Dreams..
Kirkybhoy is offline   Reply With Quote
Old 02-07-11, 10:55 PM   #8
Stenno
Fuelly.com tells me 1 mile costs me 11 pence.
Old 03-07-11, 09:48 AM   #9
tom-k6
yea its about the same for me on my sv, around the 10p per mile marker, can get it higher, can get it lower but its normally not too bad
Old 03-07-11, 09:56 AM   #10
TazDaz
You must still have about 1/3 of a tank left of its only costing you £14 to fill up.
carb fuel/running problem dazzaboy Bikes - Talk & Issues 6 09-08-10 05:47 PM
running problem - as if running out of petrol Nick8529 SV Talk, Tuning & Tweaking 20 27-10-09 11:47 AM
Fuel light = rough running? arcdef SV Talk, Tuning & Tweaking 16 26-08-09 12:52 PM
Running out of fuel. the_lone_wolf Bikes - Talk & Issues 17 24-12-08 10:06 PM
Running rough, running out of ideas. Sarj SV Talk, Tuning & Tweaking 17 04-12-07 06:45 PM
