Old 19-08-11, 04:29 PM   #1
mrrowley87
Default Problems - Clutch and Gears
A quick couple of questions -
When I pull the clutch lever in with the bike in 2nd gear should it then free wheel like I have it in neutral?
I have been trying to bump start the damn thing all day (with no success) after fitting the new Reg/Rec. (Waiting for the trickle charger I ordered off of eBay to arrive.) Should it be as easy to push in 2nd gear with the clutch in as with it in neautral?
Could it be a poorly connected Reg/Rec causing my starting issues?
Also I noticed that the rod from my left hand footrest is slightly bent and the gear selector lever is clashing with this rod.
Can I just straighten this out by hand? Is it easy to remove if I need to persuade (hammer) it flat?
If the bike is supposed to free wheel with the clutch lever pulled in what do I need to do to make this happen?
I don't know if it's due to a complete lack of electrical power but I imagine that it's nothing to do with that?
Thanks!
Old 19-08-11, 07:16 PM   #2
mrrowley87
Default Re: Problems - Clutch and Gears
So I jump started it from the battery on my car.
Zero problems with the clutch or gears once it had started up.
I will definitely need a new on of those rods though that moves the gear selector up and down? I don't know what it is called. It runs behind the foot lever. If any one has one please pm me a price?
Old 19-08-11, 07:59 PM   #3
Longway
I don't think the gear selector rod costs that much new, same rod is fitted to various models
You can get a part number and price from here
http://www.cmsnl.com/products/rodgear-shift_2552519f00/
Maybe try your local dealer if you have no luck finding used
Old 20-08-11, 07:15 AM   #4
Murph
The clutch disegages the drive, so it will be free to role with the clutch in. Regardless of the gear.
Problems changing gears. bmack999 SV Talk, Tuning & Tweaking 3 24-06-11 09:31 PM
Clutch problems. otacon88 SV Talk, Tuning & Tweaking 13 16-05-09 06:19 AM
Problems with changing down multiple gears Grinch SV Talk, Tuning & Tweaking 26 16-01-07 12:18 PM
Clutch problems from new dmracing SV Talk, Tuning & Tweaking 3 03-08-06 01:00 PM
clutch problems... SVNez SV Talk, Tuning & Tweaking 12 14-05-06 10:07 PM
