Old 03-11-11, 10:59 AM   #1
AndyBrad
Default wheel alignment tolerance.
just curious as to what sort of tolerance you need on wheel alignment. i seem to be about 2-3mm out front to back using string. is this acceptable?
Old 03-11-11, 12:32 PM   #2
HoL
Default Re: wheel alignment tolerance.
Is string that accurate? I would have thought it'd stretch a bit
Old 03-11-11, 12:58 PM   #3
It stretches out straight...
I'd get it as near as could be measured. Can you not borrow 2 lengths of angle iron or something?
Old 03-11-11, 01:36 PM   #4
AndyBrad
Just purchased a bit of alu box section to double check and found out its 2.5mm out compared to string. Just wondering how accurate it needs to be and indeed if the box section is more accurate (which i assume it is)
Old 03-11-11, 01:42 PM   #5
HoL
Where are you measuring to & from? I've only every seen wheel alignment checked using two straight anythings against the back wheel lined up against the front.
Wheel alignment ingi SV Talk, Tuning & Tweaking 6 02-02-11 05:15 PM
Wheel alignment off. DavieSV SV Talk, Tuning & Tweaking 7 19-07-10 11:08 AM
Replacement wheel bearing tolerance. lawson17 SV Talk, Tuning & Tweaking 2 16-01-10 08:22 PM
Wheel alignment, again muffles SV Talk, Tuning & Tweaking 4 29-07-07 12:26 AM
Wheel alignment Ratty SV Talk, Tuning & Tweaking 9 11-07-06 07:57 AM
