Old 24-11-11, 08:26 PM   #1
bathwiggle
Default I think it's broken, oil everywhere
I have a 2000 sv650s. 44500ish miles, ridden in all weather. I think its broken.
Riding to work today it felt like there was ice everywhere, losing it in most corners, so i, being me, assumed it was greasy roads or low tyre pressure.
At lunch i looked at her. I have a puddle of oil on the rear wheel, rear tyre coated in oil, oil all over both sides of the swing arm, all over the side stand, all over the bottom of the engine, and the exhaust system has also had its share, there is none left when i look to see if there is any in the window.
There is none on the clutch cover or around the oil filter, and the sump plug is still in place and tight.
She's still sat at work as i wasn't going to ride her home, but does anyone have any suggests as to what it could be?
Old 24-11-11, 08:28 PM   #2
Default Re: I think it's broken, oil everywhere
Driveshaft oil seal?
Old 24-11-11, 09:22 PM   #3
Biker Biggles
Biker Biggles's Avatar
Crankcase breather pipes(two to check)
Old 24-11-11, 09:27 PM   #4
suzukigt380paul
don't tell me this is a new anti corrosion modification
Old 24-11-11, 09:45 PM   #5
bathwiggle
paul- well it means she won't be going out in the bad weather until i fix it!
Guy's thankyou, i'll try and work out how i'm getting her home and go from there. I broke the car yesterday so it really was only fair the bike went today
Old 25-11-11, 10:12 AM   #6
SV650Racer
Check the oil cooler and lines for any damage too.
Old 25-11-11, 10:19 AM   #7
timwilky
timwilky's Avatar
come on Sarah keep up. It is a 2000
Not Grumpy, opinionated.
Old 25-11-11, 10:27 AM   #8
SV650Racer
Ah missed that LOL.
Old 25-11-11, 10:33 AM   #9
Check that the front sprocket nut is tight, if it's loose, (or missing - not unknown!), exactly what you're describing happens.
Old 25-11-11, 11:20 AM   #10
NTECUK
NTECUK's Avatar
If its at broomfield can Dee collect it?
Startrek.steve broken, SV650 broken too startrek.steve Bikes - Talk & Issues 31 26-08-08 12:49 PM
my car has broken down...again! josefine666 Idle Banter 17 28-11-07 11:28 PM
Broken dreams and broken lives. Peter Henry Idle Banter 7 15-09-06 07:43 AM
It's broken!!! :( alex.j SV Talk, Tuning & Tweaking 7 30-08-06 08:50 PM
My Broken SV sharriso74 Photos 6 30-07-06 09:10 PM
