Old 25-02-12, 02:55 PM   #1
rowdy
rowdy's Avatar
Default New battery and FI warning light.
Hello all, not been on here for a long while, and not ridden the bike for even longer due to bad weather and ill health. I had been hoping to get back on the saddle last summer but ended up in hospital and no fit state to ride the bike for a while, which resulted in a dead battery. I put my old battery on charge but to no avail so have just been out and fitted a new Yuasa battery. I put the battery on charge for about half an hour. It registered half charged but I thought the needle was dropping so thought the charger might be knackered and draining the battery so I connected it to the bike to see if I could start it and leave it running, try and get some charge into it that way .The dash lights up, but there is no noise from the fuel pump being primed and the FI light is lit up with FI check displayed on the dash.
Am I just being impatient, and need the battery to be fully charged or is there an actual FI problem.
Old 25-02-12, 03:49 PM   #2
Default Re: new battery and FI warning light
if CHECK is being displayed on the dash it usually means that the kill switch is in the off position. yes yes i know your not a numpty but sometimes people forget to check the obvious
Old 25-02-12, 04:10 PM   #3
rowdy
rowdy's Avatar
How do you know? I have my moments .
No, the kill switch is in its usual position, I'm thinking maybe the sidestand switch .
When I first went to start it before the new battery it didn't do anything, completely dead no sign of life on the dash. I charged the battery for days and it gave it enough juice for the dash to turn on but that was it. Now with the new battery, that was reading half charged its the same, dashboard springs into life but the fuel pump sounds dead.
Battery is on charge again and has been for nearly an hour, its reading 1/4 charged now, can a duff charger drain the battery?
Old 25-02-12, 04:32 PM   #4
any of the safety measures will stop the pump from priming (side stand, clutch, kill switch) give the connectors a good looking at then move the switch parts in and out a good few times might help free them off. to save battery power while starting disconnect the headlight bulbs by taking the connectors off.
haven't the foggiest about chargers but i would presume that the will just not charge if they are burgerd.
Old 25-02-12, 04:56 PM   #5
As Bibio says any of the cutouts could be at fault*, but get the battery back on the charger until it's fully charged - this will rule out the possibility of a low voltage being a component of the problem.
*Plenty of other possibilities too, obviously.
Old 03-03-12, 03:42 PM   #6
rowdy
rowdy's Avatar
Default Re: New battery and FI warning light.
Oh yes, rowdys a happy bunny today. Not least because I have the old girl running, thanks to my dad bringing over his battery charger but also because he has given me one of these http://www.ebay.co.uk/itm/BMW-R850GS...item27c402ba14 .
Not mine but pretty much identicle (same colour too). The old man toppled over at some lights and went straight to his local trumpet dealer and purchased a brand new Tiger 800, so he has given me his old bike. Not suprised he fell over it is a feckin heavy old lump.
The SV, well I think it was either the side stand switch or the fact it didn't want to register that it was in neutral, but a fully charged battery and with the stand up and clutch in she fired straight into life, although it sounded like a bag of spanners for a little while but has quitened down now, although for some strange reason she lurched forward and cut out, as if it had been knocked into gear but she was still in neutral .
Gear and brake lever are as stiff as an octagenarian that has swallowed a bottle full of viagra, but I have some nice shiney new Gilles rearsets to go on so no bother .
Oil warning light ranathari SV Talk, Tuning & Tweaking 11 14-05-09 10:33 PM
Fuel warning light, when? lazymanc SV Talk, Tuning & Tweaking 10 02-07-08 06:35 PM
gas light?(that'll be fuel warning light) Spanish Fly SV Talk, Tuning & Tweaking 9 08-06-07 05:45 PM
F I warning light scorpion SV Talk, Tuning & Tweaking 8 30-05-07 11:58 PM
F.I warning light caines Bikes - Talk & Issues 5 09-11-05 03:57 PM
