Old 20-03-12, 04:57 PM   #1
kiggles
Default Recomend me flush mount indicators.
i keep breaking my indicators off and its getting boring gluing them back on all the time so i need some flush mount indicators for my cbr600rr
the catch is i dont want to buy any additional equipment like resistors or rectifiers as i went through the problems of led indicators on my sv and its just one big headache
Old 20-03-12, 06:24 PM   #2
Dave20046
Dave20046's Avatar
Default Re: Recomend me flush mount indicators.
http://www.motorcyclesparesuk.com/product-p/BI2823.htm
They'd work, you only need resistors etc. if you have LED indi's and if you replace the flasher unit it's not a nightmare* worth in my opinion
*providing your brand new flasher unit isn't a dud and you panic.
Old 20-03-12, 07:09 PM   #3
kiggles
do you recon they are bulbs? and doesnt need resistors? as the resistors get hot and often break at the join over time
Old 20-03-12, 07:46 PM   #4
Dave20046
Dave20046's Avatar
LED's don't need resistors - resistors are a shortcut which make the bike's original flasher unit think bulbs are in the indicators when infact someone's fitted LEDs*. If you use LED indicators and an LED flasher unit there's no issue.
And yes they'll be bulbs - they look suitably old fashioned and don't say LED anywhere.
*probably not fully technically correct but near enough
Old 20-03-12, 07:54 PM   #5
dkid
+1. used a flasher fix relay and it's a 5 min job. fit & forget, no headaches.
Resistors also get hot so another reason not to bother with them when there's such an easy alternative.
Old 20-03-12, 08:18 PM   #6
Spriggy
How would one go about acquiring such a flasher fix relay?
Old 20-03-12, 08:22 PM   #7
Dave20046
Dave20046's Avatar
a quick google
something like that should do it http://www.ebay.co.uk/itm/2-PIN-LED-...ht_1420wt_1110 I'm sure it's a 2 pin you need. Motrax do one but they're scum and twice the price so don't buy it , mine was about £5 from local bike shop.
There's loads of threads on this with instructions and probably links too, do a search on the forum
Old 20-03-12, 08:24 PM   #8
Dave20046
Dave20046's Avatar
http://www.norbsa02.freeuk.com/goffyindicators.htm
Old 20-03-12, 09:04 PM   #9
dkid
This.
Old 20-03-12, 10:05 PM   #10
DJFridge
Wouldn't it be easier to work out how you keep breaking them? And then stop doing it?
runs away........
LED Flush mount indicators fitted - problem. Rcollarbone SV Talk, Tuning & Tweaking 19 15-05-10 06:07 PM
motrax flush mount indicators Keith1983 SV Talk, Tuning & Tweaking 0 03-08-07 01:32 PM
Oval flush mount rear indicators svrash SV Talk, Tuning & Tweaking 0 12-03-07 11:37 PM
:GROUP BUY: Watsen Design LED Flush Mount indicators volengineer For Sale - SV's and SV related items 11 03-07-06 09:27 AM
