Old 28-03-12, 11:34 PM   #1
Jayneflakes
Jayneflakes's Avatar
Default Fan switch failed.
I discovered a problem today with my bike, after I worked so hard making her lovely this last few days too.
My engine temperature started to rise dramatically while sat in traffic on the way to Hospital, no problem thought I, the fan will kick in soon.
It did not, it seems that the anti-hot switch thingie has broken. I have found that the anti-hot switch does not supply current to the fan, but both the fan and the fuse are working fine. This means that I now have to buy a new anti-hot switch and then drain my radiator to fit the thing.
In case you are wondering what I am talking about, it is the anti hot switch that sits in the radiator and switches the fan on when the radiator gets too hot. I am sure that it has a technical name, but I don't know what it is, although I imagine that it is some kind of Thermistor that controls fan function, but do not know how it should work. So from now on, it is called a Anti-hot Switch! Damn thing...
Jayne you're a Pussy Magnet
Old 28-03-12, 11:52 PM   #2
Thermostat
Old 29-03-12, 12:12 AM   #3
rictus01
rictus01's Avatar
Default Re: Grrr, Bike getting hot
Thermostat actually sits in the coolant flow and restricts the flow to aid reaching operating temp quicker.
Jayne what you need is a thremo switch.
Cheers Mark.
Old 29-03-12, 12:47 AM   #4
Jayneflakes
Cheers Mark.
Thank you, that is exactly what I need, however from this day forth, it shall be known as the anti-hot switch!
This comes after buying a new speedo magnet, servicing the forks with new oil, adjusting the clutch and now I have sat in the garage for when I feel well enough to sort it out, a new Suzuki oil filter and a can of fresh engine oil. Damn bike is being spoiled and it still asks for more... Very Dickensian if you ask me. Time to fix it with my favorite tools.
Old 29-03-12, 12:48 AM   #5
or you could just by-pass it and wire a switch in and take control.
Old 29-03-12, 01:03 AM   #6
Jayneflakes
Now this appeals to my OCD, control freak nature and is something that I have already discussed with the wife as a temporary repair!
£40 for a thermister controlled switch does seem a little steep though, can such a small part really be so expensive?
Old 29-03-12, 01:28 AM   #7
the CDI might throw a wobbly if the rad switch is disconnected so breaking into the fan wiring might be a better idea.
Old 29-03-12, 07:02 AM   #8
MJC-DEV
MJC-DEV's Avatar
Or just fix it properly!
Must be able to get a newer, working one from a breakers if you really must.
2006 SK6, wavy discs, 8.5N K-Tech springs, Debrix Emulators, Nitron Shock, Silkolene RSF Pro 10W, Eastern Beaver H4 Dual Headlight Relay Kit, Avon Storm Ultra 2 tyres, Ebay billet brake/clutch levers
MJC-DEV is offline   Reply With Quote
Old 29-03-12, 08:00 AM   #9
Were you a dispatcher in London in the 80's? Every bike had one of these for traffic holdups.
Old 29-03-12, 08:58 AM   #10
NTECUK
NTECUK's Avatar
Default Re: Fan switch failed.
Your not going to stick a hair grip in it?
I had to on the mini to get home when the switch melted
MOT Failed! Dunn-y Bikes - Talk & Issues 16 18-05-11 12:49 PM
Failed CBT - Twice Littlepeahead Idle Banter 46 12-03-10 07:41 PM
failed again shiver85 Bikes - Talk & Issues 5 17-05-08 12:04 PM
TRE mod failed on 07 vegacr250 SV Talk, Tuning & Tweaking 21 09-07-07 10:28 PM
Failed ignition switch - again seedy100 SV Talk, Tuning & Tweaking 7 05-03-07 08:47 PM
