Old 08-04-12, 01:53 PM   #1
Mykey.M
Default gsxr 400 gk76a starter/solenoid trouble.
just a quick one to see what peoples thoughts are,
got a gk76a, took it up the road for a spin before xmas and then put it away, we then had the really cold snowy weather and not it wont do anything,
the starter solenoid clicks then sounds like it spins inside?
i know the battery is low on power only 11v but even with a booster nothing at all.
could the cold of damaged something at all?
Old 08-04-12, 02:50 PM   #2
garynortheast
garynortheast's Avatar
Default Re: gsxr 400 gk76a trouble
Fully charged battery, drain the carbs and clean fuel would be a good start.
Old 09-04-12, 01:57 PM   #3
Mykey.M
Default Re: gsxr 400 gk76a starter/solenoid trouble.
The carbs are fine, it ran its just the starter.solenoied im having troubles with, it clicks and makes a turning sound from inside the solenoied, even with a booster it does the same thing, the engine Wont turn over
Old 09-04-12, 02:09 PM   #4
Solenoid can't 'spin', it's a switch, it will go click if it's correctly connected and working. Solenoid is near battery and has two fat wires and two to four thin wires, (possibly in a single plug), going to it. Starter motor is on top of gearbox, beneath carbs.
Do you mean the starter motor makes a spinning noise? If yes, then it sounds like the starter clutch is slipping, or possibly the reduction gears are damaged.
Can you bump start the bike? Note; bump, not jump.
Suzuki GSXR 400 RR GK76A £850 Mykey.M For Sale - Other Bikes and General biking items 4 25-09-11 07:08 PM
GSXR 400 GK76a rear shock Mykey.M Bikes - Talk & Issues 7 29-08-11 06:08 PM
Starter Relay\Solenoid early and late the same? Robert711 SV Talk, Tuning & Tweaking 1 26-07-10 08:52 PM
where is the solenoid for the starter motor? gedcarney SV Talk, Tuning & Tweaking 4 03-03-10 09:53 PM
Starter Solenoid. Alpinestarhero SV Talk, Tuning & Tweaking 17 15-04-09 03:11 PM
