Old 16-04-12, 12:25 AM   #1
BanannaMan
BanannaMan's Avatar
Default Bleeding rear brakes?
Just put a rear caliper on my curvy but can't seem to get all the air out by conventional bleeding.
Any tips for getting the air out?
...Bill
Old 16-04-12, 12:49 AM   #2
Default Re: Bleeding rear brakes
have you tried the. pressure, open bleed nipple, close bleed nipple, repeat method?
also you can get a small air trap in the MC so sometimes putting a rag to catch the brake fluid and then put a little pressure on the pedal and cracking the MC banjo open then closing it again before you get to the full stroke of the brake pedal gets rid of it.
Old 16-04-12, 03:21 AM   #3
BanannaMan
BanannaMan's Avatar
Cheers mate!
Problem sorted. Allow me to buy you a virtual pint.
(perhaps a real one as well next time I'm over)
...Bill
Old 16-04-12, 07:27 AM   #4
timwilky
timwilky's Avatar
Come on Bill you own a garage, do you not have a vacuum bleeder?
Not Grumpy, opinionated.
Old 17-04-12, 03:07 AM   #5
BanannaMan
BanannaMan's Avatar
I do but it's at work. Mostly sort the bike at home.
Hour round trip to there. Easier just to bring the few needed tools home unless I'm in need of the tyre changer or the acetylene chain breaker. LOL
Edit: (or the vacuum bleeder)
Wouldn't this be a nice tag for the mc pic game?
Your bike with bits being cut off. LOL
...Bill
Old 17-04-12, 08:22 PM   #6
punyXpress
punyXpress's Avatar
Default Re: Bleeding rear brakes?
Hey, Bibio - make sure it's a Scottish pint - US ones are 20% off!
Now: Street Triple R
Old 29-04-12, 04:47 PM   #7
Dave Mac
whats the mc banjo? im having the same problem with my back brakes
Old 29-04-12, 07:08 PM   #8
HoL
It's were the rear brake line attaches behind the right heel plate. I used a syringe to pump some brake fluid in through the bleed nipple with that bolt loosened then tightened it again once fluid started coming through.
Old 29-04-12, 07:44 PM   #9
Dave Mac
ill give that a bash, its annoying cos the fluid comes out both bleeding nipples, the brake pedal is really loose feeling but it does brake eventually.
cheers
Old 29-04-12, 07:52 PM   #10
muzikill
muzikill's Avatar
This week i MUST do this. pm me a day to give you back yer carbtune btw. Im backshift wed so no good on that day.
Bleeding brakes - VFR. BBadger Bikes - Talk & Issues 20 12-06-10 05:44 AM
Bleeding Brakes - Again HopefullySoon SV Talk, Tuning & Tweaking 2 28-08-07 09:13 AM
Bleeding Brakes (Bleeding Kits) 21QUEST SV Talk, Tuning & Tweaking 8 20-06-06 05:31 PM
Bleeding Brakes sweepdoggydog SV Talk, Tuning & Tweaking 9 08-06-06 07:07 AM
Bleeding brakes Samurai SV Talk, Tuning & Tweaking 6 06-06-06 05:17 PM
