Old 28-04-12, 02:16 PM   #1
svsam
svsam's Avatar
Default Cam swap timing advice?
Does anyone one have any idea what markings i would use to time curvy 'in' cams to the pointy 'out' place?
Hoping to do the swap before the 8th as its my week off and its getting mapped that week.
Also has anyone ever bored out their throttle bodies? or have any info on it?
Cheers, Sam.
SL0 jack up kit-yoshimura can-tial tidy-(so far)
svsam is offline   Reply With Quote
Old 28-04-12, 03:31 PM   #2
NedSVS
Default Re: cam swap advice
On my curvy I just moved the cam lobes on the exhaust side to a suitable rference point - peak of lobe in line with the gasket joint face. Then I swaped the cam, aligning the replacement one in a similar position. Sounds crude but it works, as a full tooth out on the chain is a noticeable amount. Hope that helps.
Sv650 cam swap - advice needed sam.nicholson SV Talk, Tuning & Tweaking 14 21-02-12 03:01 PM
Timing advice needed. muzikill SV Talk, Tuning & Tweaking 3 27-01-11 03:08 AM
Timing advice? hardhat_harry SV Talk, Tuning & Tweaking 13 29-12-10 02:30 PM
Engine timing, advice needed please ? Soprano69 SV Talk, Tuning & Tweaking 17 21-01-08 09:54 PM
Engine swap advice sixstring SV Talk, Tuning & Tweaking 7 18-01-08 09:44 PM
