Old 30-04-12, 02:51 PM   #1
chuck43
Default Cost of getting wheels painted?
hi everyone!
Thinking about getting wheels painted black. Just wondering if anyone has had this done or knows how much it costs?
Old 30-04-12, 03:46 PM   #2
muddydude
Default Re: Cost of getting wheels painted
powder coated is normally about £40 per wheel But if you want them painted do them yourself its easy aslong as you can take the discs off..good luck
Old 30-04-12, 07:20 PM   #3
Default Re: Cost of getting wheels painted?
Powercoat them
As muddydude say's it around £40 per wheel if you do all the strip on them.
I know my local dealers both deal with a powercoater who collects and delivers to there workshops
Old 30-04-12, 09:20 PM   #4
Dunn-y
Black powder coated wheels, swing arm, forks and frame with either deep red or gun metal grey tank and bodywork looks excellent. If only I could afford to. (This is for a Curvy by the way)
Old 01-05-12, 05:59 PM   #5
muddydude
I did mine myself but with polished rims..was easy for my first time..go on give it a try..self satisfaction m8...I just did my fork seals for the first time and pretty chuffed
Old 01-05-12, 06:08 PM   #6
rictus01
rictus01's Avatar
although powdercoat is a more durable finish to start with; I've found on wheels it tends to get stone chipped, once this happens (if you're not quick to catch it/a small dab of clear nail varnish seals it again) water gets under it and ruins a far larger area, normal paint doesn't suffer the same way so touchups can be left longer and are far easier, as others have said, you don't need to do a perfect job when painting them, you don't even need to remove the tyre, just release the pressure and mask up under the rim then re-inflate once done.
Cheers Mark.
Old 01-05-12, 06:17 PM   #7
Viney
Agree with Rictus. I had my wheels powdercoated several years ago. The rear one chipped and to be honest i didnt catch it, not the rear is stripping itself quite happily. Oh, and never paint them anything other than black.
I probably would still have them redone as it lasted about 4 years, which for me is about 30k
Old 01-05-12, 06:17 PM   #8
I agree with Mark's double posting
Once powder coat get's chipped, then it'll start to flake off. It'll stay soft underneath so a clumsy tyre fitter could easily ruin your fresh powdercoat when re-fitting your tyres.
Also you'll have to remove the wheel bearings before you get the wheels powdercoated, whereas if you paint them, you can just mask the bearings off
Old 04-05-12, 09:55 AM   #9
chuck43
thanks everyone for all your answers. My Uncle is a painter for historic sports cars and used to work for BAR f1 team in paint shop so i asked him for ball park fiqure. He said, if i take him just the wheels with everything off But not tyre, he charge £80 but for £120 i can just drop the bike at his.
painted or powder coated wheels muddydude SV Talk, Tuning & Tweaking 5 17-08-11 07:33 PM
Where to get wheels painted allantheboss South & West Surfers 24 08-02-10 06:40 PM
K6 Painted Wheels amuli SV Talk, Tuning & Tweaking 26 16-03-07 03:56 PM
Painted wheels or powercoated james160987 Bikes - Talk & Issues 14 21-12-06 09:49 AM
Painted Callipers anyone? Rodger Wabbit Bikes - Talk & Issues 11 03-02-05 04:42 PM
