Old 21-07-12, 12:01 PM   #1
granty92
Default Where's the idle screw
Ive noticed the bike rpm is idling at about 900 which doesn't sound right, also if I blip the throttle the bike stalls, I know I need to adjust the idle but where is the idle screw?
Old 21-07-12, 12:26 PM   #2
SoulKiss
SoulKiss's Avatar
Default Re: Where's the idle screw
Left side, you can see it in the "trellis" of the frame.
Top tip - you dont need a screwdriver, if you reach behind to the actual cable, you can twist the cable itself - clockwise to increase the idle (I think).
Dont forget to blip the throttle between tweaks.
Old 21-07-12, 12:35 PM   #3
granty92
Cool thankyou
Old 21-07-12, 02:57 PM   #4
unclepoo
What is the recomended tick-over speed...when i go my sv it was about 1000rpm and stalled quite easy, and was jerky to ride and roll off the gas. I found a tick over of 1400rpm was much better, but now I`ve adjusted the tps the jerkyness has gone and my tick over is set at 1100rpm.
Old 21-07-12, 04:09 PM   #5
1300+/-100
Old 21-07-12, 04:33 PM   #6
metalmonkey
Are you meant to adjust this when the bike is fully up to tempature?
Old 21-07-12, 06:35 PM   #7
dirtyred619
Yep and make sure you blip the throttle after you've made an adjustment.
Old 21-07-12, 07:15 PM   #8
If the adjuster does sod all, unclip it and try again.
I've found it easier to go to 1700 and then bring it down slowly.
Factory should be 1300 +/-100 I've found 1400 hot to be easier cold
Idle Adjuster Screw mattglavin SV Talk, Tuning & Tweaking 11 11-10-07 12:37 PM
Two up / Screw up John 675 SV Talk, Tuning & Tweaking 63 06-03-07 11:25 PM
Idle adjust screw? jec444 SV Talk, Tuning & Tweaking 6 01-07-06 02:53 PM
Bloody idle screw! Mervin SV Talk, Tuning & Tweaking 16 04-02-05 08:00 AM
