Old 30-09-12, 03:18 PM   #1
JonGeorge
Default Battery voltage question.
Hello,
is 12.65 volts across the battery enough to start a cold sv650 curvy ?
Old 30-09-12, 03:43 PM   #2
speedyandypandy
Default Re: Battery
The voltage could be 13.7V and not be enough, a duff battery could get high voltage but low on amps and cranking power. The only way to really know is a load test, if you can't do it yourself it's cheaper buying a new battery then getting someone to do it.
What should a good battery voltage be? SVspeedr SV Talk, Tuning & Tweaking 62 22-08-16 05:27 PM
Battery voltage help Geodude SV Talk, Tuning & Tweaking 44 15-05-13 05:48 PM
Fully charged battery voltage? metalmonkey Bikes - Talk & Issues 2 16-07-12 09:46 PM
Reg rec voltage question. Stonesie Bikes - Talk & Issues 10 17-03-11 01:16 PM
Motorcycle Battery Voltage Monitor Lucas SV Talk, Tuning & Tweaking 21 27-02-10 08:32 PM
