Hi Guys
Anyone know how the clutch gets it's oil supply? It it fed or does it simply sit in oil? I have tried everything to stop mine dragging:- - Adjusted according to Haynes manual several times - Replaced friction plates - Replaced steel plates - Replaced oil filter and oil with Rock Oil Semi 10w 40 The clutch seems to be okay when cold and starts to drag when hot. I am now wondering if I have blocked an oil passage (if there is such a thing) that supply's the clutch as I have used that nasty gasket paste a while ago. It's driving me crazy any help would be great. Oh and mileage is about 55k now |
What is the oil level at? If you have too much oil in the engine, it will cause the clutch to drag. I run mine just over half way up the glass window.
Thanks for the reply.
I have tried all levels. I ride just over 500 miles a week and top oil up to the top once it gets to the bottom. Doesn't seem to effect the clutch drag much but will keep an eye on it. |
Had something similar a few years ago and it was much improved by getting a new worm drive actuator thing.The bit that you adjust with a screwdriver by the front sprocket.Mine seemed fine,but was quite worn due to getting grit and carp in it.
running mine at full had the affect you're describing-fine when cold, sluggish when hot and impossible when hot and stationary.
try running it at half way and keep a good eye on the level. hopefully this will help |
Lol carp in it would cause problems! I think that is going to be the next part I change. If it was the worm though I would expect it to be difficult to shift when cold aswell. It may still be down to the worm not providing enough movement so I will look at changing it. When I watch the pushrod move it seems to move a fair amount when i pull the clutch lever.
#7 | |
Lifter most likely/easiest to fix, check it carefully for wear and lost motion, failing that it may well be a notched clutch basket
Cold, thin plates sit in notches on basket = works fine. When the plates get hot they expand but can't split neatly as they hang in the notches even under no spring pressure = draggy clutch when hot.
#9 |
Thanks Sid. I have wondered what a notched basket is and that makes sense. I will replace lifter first and then inspect the basket. I guess these notches could be hard to spot?
Clutch dragging/stuck. | Rossie | SV Talk, Tuning & Tweaking | 2 | 29-01-11 06:24 PM |
Clutch Problem? Cutting off when releasing clutch in first gear! | puthsardarade | SV Talk, Tuning & Tweaking | 15 | 09-01-08 09:42 PM |
Dragging Clutch help | SVStu | SV Talk, Tuning & Tweaking | 2 | 24-08-07 01:31 PM |
lost neutral & dragging clutch | weazelz | SV Talk, Tuning & Tweaking | 6 | 24-05-07 11:49 AM |
My clutch problem | TSM | SV Talk, Tuning & Tweaking | 21 | 08-09-05 08:42 PM |
