Old 17-12-12, 12:22 PM   #1
DipperSV650
Default SV650 K2 2002 Engine Coolant leak
Hi all, new to the forum.
Ref: SV650 K2 2002 (no mods)
I recently noticed a coolant leak from the engine, around the area behind the coolant drain bolt, but not the bolt itself. Before removing anything I was wondering if that section has a gasket or do they use M12 crush washers.
Would like to try the cheaper fixes first before looking at pump issues etc.
Thanks, any help is good. Can get photos if it helps?
....just thought i had better mention, I changed the fuel tank a few months ago, don't know if that would effect anything.
Old 17-12-12, 01:17 PM   #2
m`baubz
Default Re: SV650 K2 2002 Engine Coolant leak
check out my thread for possible cheap fixes:
http://forums.sv650.org/showthread.php?t=184315
Old 17-12-12, 02:59 PM   #3
DipperSV650
Thanks m`baubz.
Coolant leak Dinglespeed SV Talk, Tuning & Tweaking 6 30-04-12 01:41 AM
2001-2002 SV650 engine wanted Preston Stuff Wanted 1 12-09-11 10:37 PM
Coolant Leak slloyd Bikes - Talk & Issues 9 21-09-10 10:30 PM
coolant leak SimJ SV Talk, Tuning & Tweaking 0 02-05-07 11:05 PM
Speedo Rotor & Engine coolant leak Nitzer SV Talk, Tuning & Tweaking 2 02-01-07 09:20 PM
