Old 17-02-13, 01:04 AM   #1
Sparky5583
Default Cheapo lever and clutch switch?
Hi all I've just brought some shorty levers from china, after fitting today I noticed that the lever no longer operates the clutch switch!
Is this common (supposed to be like this) or have I brought a cheap piece of s*+t?
Any help would be helpful thanks mark
Old 17-02-13, 05:49 AM   #2
dazuk
Default Re: Clutch switch?
sorry i can help you on that one but mine has been bypassed so i dont need to pull the clutch in to start it maybe a idea for yours.
darrell
Old 17-02-13, 08:38 AM   #3
Geodude
Geodude's Avatar
Some of the cheap levers have a cutout on the underside of the lever to operate the switch and some dont, so you pay your money and take your chance. Mine luckily had the cutout on the underside of the lever and are also adjustable (are yours?) but will only operate the switch on the top two settings. HTH
Edit: have you tried the old lever back on the bike just to make sure you didnt upset the switch when changing lever over? just a thought
Old 17-02-13, 08:55 AM   #4
Geodude
Geodude's Avatar
Found a picture showing the small notch for switch next to mounting hole, does your new one have this and is it in the same position as the old one?
Old 17-02-13, 09:00 AM   #5
dirtydog
Knob faced knobster
dirtydog's Avatar
Just bypass the switch then it's all sorted
2011 Speed Triple 1050
Old 17-02-13, 01:46 PM   #6
Sparky5583
Sorry should have said I've got a 2011 model! So I don't think that notch will make any difference
Old 17-02-13, 03:26 PM   #7
MJC-DEV
MJC-DEV's Avatar
I found that lever setting 1 wouldn't operate the switch. Not a problem for me as I use 3 but could have been fixed with a little packing in the lever switch slot.
2006 SK6, wavy discs, 8.5N K-Tech springs, Debrix Emulators, Nitron Shock, Silkolene RSF Pro 10W, Eastern Beaver H4 Dual Headlight Relay Kit, Avon Storm Ultra 2 tyres, Ebay billet brake/clutch levers
MJC-DEV is offline   Reply With Quote
Old 17-02-13, 03:39 PM   #8
Sparky5583
Picture with new one fitted and old one next to it you can see that the new one does not have the downwards protruding tab to operate the switch, the bike will now start without pulling the clutch in
Old 18-02-13, 04:09 PM   #9
SV650Racer
Default Re: Cheapo lever and clutch switch?
The bike needs the clutch switch operational as without it, even if bypassed will run in a neutral ignition and fueling map.
All injected Suzuki's are the same and on a GSXR600 06 onwards the bike looses around 30bhp!
Old 18-02-13, 04:51 PM   #10
Sparky5583
Thanks guy I've now got in touch with the seller and he's sending me right one hopefully
Gear lever and clutch lever wanted curvy pauldogs Stuff Wanted 2 18-08-11 08:51 AM
Curvy clutch lever and gear shift lever ibanezlynx Stuff Wanted 4 25-04-11 11:02 AM
RH Footpeg Hanger, Rear Brake Lever and Clutch Lever for 2004 Naked Wanted Drumming_Animal Stuff Wanted 0 26-07-10 10:52 PM
K5 Pointy 650S right hand wing mirror, gear lever and clutch lever. Bayside GTR Stuff Wanted 0 29-10-07 11:24 PM
2 left indicators + clutch lever + gear lever for pointy k6 enduroman Stuff Wanted 3 06-09-07 09:26 PM
