Old 28-06-13, 11:30 AM   #1
a_monkey_hint
Default Frequently check your oil level kids!
Noticed quite alot of oil on the underside of my bike & no oil in the window (breather hose disconnected from airbox - which has since been reconnected).
Instead of topping up it was due an oil change, so did an oil and filter change and got all of 1700ml out!
I'm not entirely sure how the bike was still running!
Old 28-06-13, 11:44 AM   #2
Pricey12
Default Re: Frequently check your oil level kids!
At least you spotted it when you did.
Could have been very expensive otherwise
Old 28-06-13, 12:59 PM   #3
Owenski
Thought full was only 2300ml, 600ml short isnt too bad. You must have noticed quite early congrats.
Old 28-06-13, 04:45 PM   #4
a_monkey_hint
Full is 2700 (incl oil filter) or 2500 without filter change.
Old 28-06-13, 05:50 PM   #5
Owenski
Ah fair enough so you were a good litre short. Doesn't take long to come out though once you have a substantial leak.
All the best with the fix
How often do you check your oil level and can i buy bulk bottles of oil? stuR Bikes - Talk & Issues 25 10-06-13 01:24 PM
Brake Fluid Resevoir Diaphragm and level check branny SV Talk, Tuning & Tweaking 11 27-01-09 04:11 PM
Check your oil level! breakz187 SV Talk, Tuning & Tweaking 25 11-12-08 01:28 PM
How to check fuel level? flymo Mini-Twins 1 29-01-08 05:05 PM
Coolant level check... how? ujoni08 SV Talk, Tuning & Tweaking 6 29-06-05 08:39 PM
