Old 02-06-13, 06:07 PM   #1
stuR
Default How often do you check your oil level and can i buy bulk bottles of oil?
So it occured to me ive been doing alot more riding than usual down to the fact i have been doing alot of advanced training. I am otherwise usually fairly diligent about the maintainence of my bike, but have neglected to check the oil level for about 1.5k miles since i last changed it, and i had to put about 600ml to raise it back to the top of the dipstick(it was even touching the bottom!)
I was wondering what benchmark you guys use for checking the oil? I realise different/older bikes will burn it at different rates (like simons shed..)
Also, is there a more economical way to buy bike oil, or a cheaper brand? At present i have been using castrol 4t but its over £30 for 4l, and on the cb500 i am changing the oil every 2.5/3k. When i get on the gsxr the recommended interval is 4k, so i was wondering if there is a 25l bulk bottle or something as my dad also rides so we could share it.
Old 02-06-13, 06:14 PM   #2
Mark_h
Mark_h's Avatar
Default Re: How often do you check your oil level and can i buy bulk bottles of oil?
I check mine each time I take the bike off the driveway but as the SV has a sight glass it's no trouble. As for buying oil I stock up when HG have a special offer. Get almost two changes out of a can.
Minister for Sustainability
Old 02-06-13, 06:14 PM   #3
Tomor
Tomor's Avatar
I check mine once a week, regardless of miles. I think some companies do sell oil in 25L drums, but generally only to the trade (garages) Ask around and im sure you may be able to find one.
Yam XT125R - Sold SV650 -Sold DL 650 K6 - Sold
2012 Street Triple R - For Sale - Linky here
Tomor is offline   Reply With Quote
Old 02-06-13, 06:19 PM   #4
squirrel_hunter
squirrel_hunter's Avatar
I never check the oil level, I just replace engines.
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 02-06-13, 06:20 PM   #5
muzikill
muzikill's Avatar
I check mine everytime it gets put back in its bed after a ride.
Old 02-06-13, 06:24 PM   #6
Dabteacake
Find somebody with a halfords trade card and then buy more with the savings!
Old 02-06-13, 06:26 PM   #7
sniff
sniff's Avatar
Check as and when I remember. Which shouldn't be too hard. But I do remember every couple of weeks.
Oil I get as a freebie from work. Well I say work in a very loose way.
sniff is offline   Reply With Quote
Old 02-06-13, 06:29 PM   #8
stuR
Yea the gsxr has a sight, so will be alot less of a faff to check. Hein gericke Mark? Thought theyve shut down or do you buy it online from their eu arm? Good idea on halfords trade card, i have a mechanic mate..
Old 02-06-13, 06:33 PM   #9
Mark_h
Mark_h's Avatar
HG in Farnborough is still trading.
Old 02-06-13, 07:01 PM   #10
Fallout
Fallout's Avatar
4 x 1 litre bottles tends to only be pence more expensive than the 4 litre bottles, so by that logic I wouldn't expect mahooosive cans to be much cheaper. It's just one of those areas you'll have to take the hit on I'm afraid stu.
MotoGoLoco - You knows it
Fallout Breakbeat (My Music)
Does bulk help in a crash?! ChrisCurvyS Bikes - Talk & Issues 35 16-10-12 02:05 PM
Brake Fluid Resevoir Diaphragm and level check branny SV Talk, Tuning & Tweaking 11 27-01-09 04:11 PM
Check your oil level! breakz187 SV Talk, Tuning & Tweaking 25 11-12-08 01:28 PM
How to check fuel level? flymo Mini-Twins 1 29-01-08 05:05 PM
Coolant level check... how? ujoni08 SV Talk, Tuning & Tweaking 6 29-06-05 08:39 PM
