Mini-Twins Goto Minitwins Official Site
Old 02-07-13, 06:52 PM   #1
rvracing
Default front axle security
am i missing something here, the front axle of curvy passed through the spacer in the right hand fork yes? then through another spacer up to the wheel yes ?, then through the bearings and onto the other side of the wheel, in my case my own spacer, then passes into the thread in the left fork, ok so far, then after that there are 8 mm bolts that clamp the axle in place after tightening the axle, how then is the axle clamped by the 8mm bolts, if the axle passes through spacer? surely the the 8mm bolts are clamping the spacer not the axle, ! , we note with interest that the pointy front axle is a very different design, allowing the actual fork to clamp the axle using one 8mm bolt, am i being thick,
Old 03-07-13, 03:39 PM   #2
bikerjay
Default Re: front axle security
I dont know much about curvy's but by the sound of it is the hole in the right leg bigger than the spindle so it has a spacer to fill it out that the spindle passes through? If that is the case, I know what you mean. You would just need to lock wire the end of the spindle.
Jay.
Front axle advice... ibanezlynx SV Talk, Tuning & Tweaking 3 09-07-11 06:23 PM
Injected Front Wheel Axle and Front Master Cyl Brkt adjblade Stuff Wanted 2 19-01-11 08:07 AM
Front axle grease rob13 SV Talk, Tuning & Tweaking 1 03-09-07 06:43 AM
Front axle bolt TSM SV Talk, Tuning & Tweaking 6 04-08-05 06:51 PM
front axle cracks?? sv650fool SV Talk, Tuning & Tweaking 6 05-04-05 11:24 PM
