Old 13-07-13, 09:59 AM   #1
Coloradolovin
Default Fuse keeps blowing
Ok so I installed led lights I have them hook up in this Oder.
2 Led lights, positives twisted together and positive power cable twisted in with it then the positive connected to toggle then ran to power Positive cables connected and right after the battery I have fuse.
Negatives to LEDs cable connected together, Negative cables connected to frame.
Ok so with the switch on I can put a fuse in wont blow.
But as soon as I flip the switch to off the fuse blows
It's a 12v battery and the lights are for 12v the lights pull 0.38 amps so I put a 5 amp fuse it popped then a 10 it pop to ONLY when I turn the switch off..
What could it be????
New reg-rec, now blowing fuse. allantheboss Bikes - Talk & Issues 16 07-07-10 08:20 AM
Fuse keeps blowing benjyman Bikes - Talk & Issues 10 03-06-09 12:52 PM
fuse keeps blowing bobm SV Talk, Tuning & Tweaking 5 23-10-08 07:57 AM
Ignition Fuse blowing Frogman SV Talk, Tuning & Tweaking 7 16-04-07 05:57 PM
HELP...keep blowing a fuse jessie SV Talk, Tuning & Tweaking 5 24-03-05 10:01 PM
