Old 14-07-13, 02:46 PM   #1
BikerCraig
Default New axle nut fitted.
Suzuki put a rather shoddy looking axle nut on the sv but I found a bloke on ebay selling stainless axle nuts for a few models of triumph (some of which fit the sv. . . rocket 3 and late gen daytona 675 ar a couple) and after putting the new nut on along with a set of bibio's stainless adjuster plates it looks lovely, and at 7 quid I'd say a bargain when compared to 15 for the same thing from pro-bolt. Check on ebay for anyone else interested in upgrading their nuts
Old 14-07-13, 04:32 PM   #2
Grant66
Grant66's Avatar
Default Re: axle nut
A link would be useful
Formerly known as Gajjii
Previous Bikes: Red Sk1 Curvy, Red MT-07.
Current Bike: Black MT-09.
Grant66 is offline   Reply With Quote
Old 14-07-13, 04:38 PM   #3
21QUEST
21QUEST's Avatar
Are the nuts self locking?
I did a search on Ebay and unless I'd picked the wrong ones, they don't appear to be self locking nuts
Nemo me impune lacessit.
Old 14-07-13, 09:17 PM   #4
BikerCraig
Default Re: New axle nut fitted.
No they are not self locking, never seen a self locking axle nut on an sv to be honest. Standard nut wasn't self locking?
Item number 181175318763
Old 14-07-13, 09:28 PM   #5
21QUEST
21QUEST's Avatar
Yup, the standard nut is self locking.
If not self locking then bike manufacturers would usually use a drilled axle/cotter pin arrangement...Kawasaki tends to use that.
Old 14-07-13, 09:47 PM   #6
BikerCraig
Is it, the one that came off my k3 is just a smooth backed flanged 24mm nut and so was the one on my previos sv a k5?
Old 14-07-13, 10:01 PM   #7
21QUEST
21QUEST's Avatar
Certainly is self locking on the Curvy and I'd doubt it'd be any different on the Pointy.
Every bike I've owned, from my recollection, has either come with a self locking nut or a cotter pin arrangement.
Personally, I wouldn't use an axle nut that wasn't installed using an arrangement that prevented it from backing off.
Old 14-07-13, 10:06 PM   #8
r0ddy
r0ddy's Avatar
Really? I was under the impression they were not self locking as I'm pretty sure any bike I've owned has had a standard flanged.
As you seem pretty confident, Just out of interest what makes the nut self locking?
As far as I wa aware the only way to do that was with a nylon insert, castellated nuts or the two metal fins to lock the nut on.
r0ddy is offline   Reply With Quote
Old 14-07-13, 10:14 PM   #9
21QUEST
21QUEST's Avatar
Probably easier to put up some links.
First link shows the type usually used on bikes.
http://search.babylon.com/imageres.p...t&babsrc=SP_ss
http://www.fastenright.com/All-Metal...-products.html
http://en.wikipedia.org/wiki/Locknut
EDIT: I was typing as you edited your post.
Indeed, different methods can be used to prevent the nut backing off. It's possible a case of you just not noticing.
Old 14-07-13, 10:16 PM   #10
BikerCraig
Fair enough, ive had all the opposite, 03 sv, 05 sv, and 02 bandit 6 all with a normal flanged nut just torqued to spec. If I was truely that worried I would put a spot of locktight on it but ive never had a axle nut come loose. Pro-Bolt is the other option and theirs has a captive washer but that's 15 quid for a nut
front axle security rvracing Mini-Twins 1 03-07-13 03:39 PM
Drill through axle? Galviniser SV Talk, Tuning & Tweaking 0 30-06-11 08:29 AM
Rear Axle Nut TheOnlyNemesis SV Talk, Tuning & Tweaking 9 19-01-10 08:26 PM
Pointy Axle adjuster - please help ! RGV250ads Stuff Wanted 1 16-03-09 10:02 PM
Front axle grease rob13 SV Talk, Tuning & Tweaking 1 03-09-07 06:43 AM
