Old 30-07-13, 07:10 PM   #1
TCochrane
Default Rear Brake Feeling Off
Bike: SK3 SV650s with standard brakes
First noticed a difference straight after I had a new rear tyre put on the bike a couple weeks ago.
Rear brake feels like pressing a sponge, only slightly slowing the bike, no matter how hard I stamp on the brake. Feels very vague.
Have just used brake cleaner on the disc and pads and wiped with a clean cloth to remove any dirt / grease. Also replaced the brake fluid (which didn't have any air bubbles in)
Can anyone offer any info as to why the rear brake feels very different and weak?
Thanks,
Tim
Old 30-07-13, 07:11 PM   #2
DJ123
DJ123's Avatar
Default Re: Rear Brake Feeling Off
Have you serviced the calliper recently?
BMW F800ST
Old 30-07-13, 07:18 PM   #3
TCochrane
Not in the year that I've owned it, don't know about before
Old 30-07-13, 07:19 PM   #4
Runako
****, you use the rear brake?
Check the pads for any signs of contamination. Where did you bleed the rear brake from?
Stamp harder?
Old 30-07-13, 07:20 PM   #5
DJ123
DJ123's Avatar
I'd service the rear calliper. take it apart, clean it up. new seals and grease it up
BMW F800ST
Old 30-07-13, 07:47 PM   #6
Mark_h
Mark_h's Avatar
If you've just had the rear wheel off I'd be checking that the pads weren't knocked out of place when the wheel was put back. I once managed to get both pads on the same side of the disk once. That had an interesting impact on braking efficiency.
Minister for Sustainability
wanted: curvy rear brake lever and rear right indicator bluebeast Stuff Wanted 6 17-10-12 05:26 PM
wanted: rear brake lever and rear right hand indicator for curvy bluebeast Stuff Wanted 0 16-10-12 12:46 PM
Wanted pointy rear undertray or tail tidy, braided brake lines, wavy brake discs. Chris*2700 Stuff Wanted 3 07-10-12 11:25 AM
Curvy brake lever & rear brake pedal Old Git Stuff Wanted 1 09-01-10 11:00 AM
Cleaning all around the rear wheel / swingarm / rear brake caliper Camel SV Talk, Tuning & Tweaking 12 28-04-08 02:00 PM
