Old 12-08-13, 10:21 AM   #1
Mitch
Default Chain needs constant adjustment.
Hi Guys
I noticed the other day that my chain was very loose, so adjusted it straight away. A couple of days later the chain was very loose again.
Is the chain knackered or could it be something more sinister?
Bike is a curvy S.
Many thanks
Mitch
Old 12-08-13, 10:29 AM   #2
savage86
Default Re: Chain problem
Time for a new chain by the sounds of it. Check your sprockets while your at it. If your going to do one more than likely to do the lot.
Old 12-08-13, 10:34 AM   #3
nikon70
new chain needed, it keeps stretching so sooner rather than later, sprocket change too.
Old 12-08-13, 10:57 AM   #4
Mitch
Thanks for the quick responses
Old 12-08-13, 04:01 PM   #5
Default Re: Chain needs constant adjustment.
New chain and sprockets required. Do the set
Old 12-08-13, 04:12 PM   #6
Mark_h
Mark_h's Avatar
Also check your wheel nut is tight
Minister for Sustainability
Old 12-08-13, 06:58 PM   #7
stuR
As above chain nacked mate
Old 12-08-13, 11:12 PM   #8
screamingnoob
Make sure the chain is oiled as well if you oil the chain regularly you shouldn't have to adjust it that much
Old 13-08-13, 04:01 PM   #9
Mitch
Thanks for all your help.
Wheel is always torqued up and the bike has a scott oiler fitted.
Old 13-08-13, 09:14 PM   #10
wideguy
Surely, everybody is running sealed lube chains, which generally won't get longer until the internal grease dies or goes away. When that internal grease does die or go away, your chain will start to lengthen. Get ready for a new chain when this happens.
chain adjuster problem steveg SV Talk, Tuning & Tweaking 6 11-09-06 06:01 PM
Problem with bike!! Chain??? HELP! zurv SV Talk, Tuning & Tweaking 6 04-06-06 01:56 PM
Problem with chain adjustment. Dapper Dan SV Talk, Tuning & Tweaking 5 19-03-06 07:34 PM
Chain problem? rob13 SV Talk, Tuning & Tweaking 8 26-01-06 11:36 AM
Posssible Chain Problem briclark1 Bikes - Talk & Issues 2 31-01-05 09:16 AM
