Old 05-10-13, 11:53 AM   #1
Mrs_giggles
Question Air filter lifespan?
Just checking as I think I know the ans to this
checked my air filter on trike has written that it was last changed in 2004 and needed changing at 24000 miles mext ky trike has done 37000 and the air filter os black its having power issues couldnthis be part of problem, as i presume its not supposed to be black
Old 05-10-13, 12:42 PM   #2
Mrs_giggles
Default Re: air filter
New one puchased on evil bay be here tue, at least I have learnt new skill can change the filters now.
Old 05-10-13, 05:36 PM   #3
Default Re: Air filter lifespan?
I want to seriously see this air filter!
A choked filter does cut performance quite a bit. Mine got changed after 10 years on the bike and the engine gained back a noticeable amount of Power and torque
Is it running like it was at the GM?
Just thinking out loud after the breakdown you had at GM
Old 05-10-13, 06:15 PM   #4
Old 05-10-13, 06:23 PM   #5
What I bought it at 9 years old
Old 05-10-13, 07:26 PM   #6
Mrs_giggles
Yeah just like it was at gm has been fine for a while then went again when dave using for work will take a pic and post it up tomorrow
Old 05-10-13, 07:34 PM   #7
well there's your problem right there.. you let Lord Preston use it.
Old 05-10-13, 07:43 PM   #8
Its probably worth working through the following things (had a bit time to think on it):
- Do the air filter
- Seal the tank with POR15 kit or similar http://www.frost.co.uk/por15-motorcy...epair-kit.html
- Rebuild the Fuel tap and change the hoses (if you haven't already done it), adding an external fuel filter in
- Get the carb bowls open and give them a clean out (budget for a full rebuild)
- Carb balance
I'm going off what issues I had a few years ago with fuelling
Also shouldn't have yet lanky use it
Old 05-10-13, 11:10 PM   #9
Mrs_giggles
Usually he doesn't but since the theiving scum nicked his we cant get it to work. We think that in cutting the wiring loom it blew the ecu just and only way to het it repaired is for dave to earn some lolly.... so needs must. Butt I suppose it was found oit now jot 6 months down the line, when weather os picking up
Old 06-10-13, 06:36 PM   #10
Mrs_giggles
Another problem today power loss eorse but not from engine, rear end not responding and grinding noise, take a closer look and nolt ehich holds fiff to frame gone diff has dropped 1/2 inch, thank christ I spotted it otherwise I would have been looking at dnapped drive shaft or mullered diff, dome boging with an spare sv engine bolt and its now seated correctly snd running smoother.
engine lifespan? sv650. greywolf SV Talk, Tuning & Tweaking 10 16-10-11 07:53 PM
Carbon cans lifespan? chilli SV Talk, Tuning & Tweaking 11 11-12-09 09:19 PM
What is the Average Chain Lifespan? COLZO SV Talk, Tuning & Tweaking 16 29-01-09 08:24 PM
How long is a helmets lifespan? Monkey6879 Bikes - Talk & Issues 28 05-02-07 01:11 AM
anyone know the lifespan of the clutch, should I change it? GooseSVSK2 SV Talk, Tuning & Tweaking 2 20-01-06 09:47 PM
