Old 09-10-13, 10:17 AM   #1
granty92
Default Standard or iridium spark plugs? K3.
so i have standard plugs on my 03 pointy and im about to order new ones in a moment, what the difference between standard plugs and iridium? power difference or fuel economy?
Old 09-10-13, 10:46 AM   #2
embee
embee's Avatar
Default Re: spark plugs
You won't notice any difference in power or economy, assuming it's actually running properly anyway.
What they offer is improved initiation of the burn and lower voltage requirements from the rest of the ignition system. In simple terms it will start more easily and run more consistently. The differences are subtle, you may or may not notice anything. They also help when the fuelling is less than perfect, for example carb engines cold starting and running off choke sooner, or tip-in after overrun when fuelling tends to struggle.
They do also last somewhat longer than the traditional design, but again that may not actually be much of an issue to you.
Personally I use iridium plugs wherever possible, it's relatively little oncost in the big scheme of things (e.g. fuel, tyres, insurance, road tax etc) and as such there's not much reason not to fit them.
Be aware there are reportedly some fake NGK iridium plugs about, so buy from a reputable source.
Old 09-10-13, 10:48 AM   #3
granty92
nice one cheers yeah i'll buy them from the bike shop down the road
Old 09-10-13, 04:53 PM   #4
embee
embee's Avatar
Default Re: Standard or iridium spark plugs? K3.
If you want a reliable online source, I've always had good service from http://www.spark-plugs.co.uk/ , nearly always next day delivery. Prices are a little higher than some fleabay sellers, but probably quite a bit less than a bike shop, and they are reputable. (No connection with them, just a customer).
Old 09-10-13, 07:48 PM   #5
wideguy
The good feature of iridium plugs is they last a very long time. If you're planning on changing your plugs per the maintenance schedule, use cheaper plugs.
Old 09-10-13, 09:04 PM   #6
Ninthbike
I just bought some on ebay for £6.25 each with free delivery. Arrived this morning and will fit them as soon as I get half an hour. Had them on my Hornet and they were great - did about 8000 miles with no issues and still going strong when I changed it.
Old 09-10-13, 09:13 PM   #7
wideguy
My RC-51 came stock with iridium plugs. I checked them at 12.000 miles. They looked good and the gaps were as new, so I put them back in. I changed them at 24,000, but I don't know why, they still looked good and had gaps as new.
Old 10-10-13, 10:26 AM   #8
granty92
cheers for the link embee just ordering them now and should have them on by the weekend provinding they arrive by then. thanks for the info all
How many spark plugs? craig dow SV Talk, Tuning & Tweaking 3 19-03-12 09:08 AM
Which spark plugs? Ceebl SV Talk, Tuning & Tweaking 10 05-04-10 02:07 PM
spark plugs daddy_sperm SV Talk, Tuning & Tweaking 12 01-03-06 06:12 AM
Spark Plugs fred_dillon SV Talk, Tuning & Tweaking 5 19-06-05 06:45 PM
spark plugs weegaz22 SV Talk, Tuning & Tweaking 4 04-08-03 05:04 PM
