Old 13-04-14, 06:22 PM   #1
byron126
Smile Potential problem with braided lines?
Hi guys fitted some wezmoto braided brake lines to the front of my bike today and apart from when squeezing the lever (definitely more solid than stock lines) the actual reach of the lever before the brakes engage has remained the same, just wanted to see whether this has been the case when you've fitted braided lines or if something else could be the cause? (Stock levers by the way)
Any help appreciated
Old 13-04-14, 07:01 PM   #2
Mark_h
Mark_h's Avatar
Default Re: Potential problem with braided lines?
Why would you expect it to change?
If you change the master cylinder or the calliper you may get a change in travel. I can't see any reason for the lines to change the travel unless your old ones used to balloon massively.
Minister for Sustainability
Old 13-04-14, 07:32 PM   #3
byron126
Just wasn't sure what to expect from braided lines and having completely redone the brakes recently wasn't sure as to whether something else could be causing it.
Old 13-04-14, 08:44 PM   #4
Tomor
Tomor's Avatar
As long as the brakes work well, and there are no leaks, job done no?
Sent from my HTC One_M8 using Tapatalk
Yam XT125R - Sold SV650 -Sold DL 650 K6 - Sold
2012 Street Triple R - For Sale - Linky here
Tomor is offline   Reply With Quote
Old 13-04-14, 09:31 PM   #5
byron126
I completely agree, just wanted to make sure I wanted missing something
Old 14-04-14, 11:15 AM   #6
johnnyrod
johnnyrod's Avatar
The reduced bulging of the lines gives a firmer feel but the initial travel is a combination of any air in the system, and the lever travel needed to push the pads onto the discs fully.
Braided oil lines - where from? TheRuffellator SV Talk, Tuning & Tweaking 4 12-05-13 10:05 PM
Braided Lines M65 SV Talk, Tuning & Tweaking 10 26-06-05 02:02 PM
HEL Braided lines Couerdelion SV Talk, Tuning & Tweaking 7 30-05-05 07:13 AM
HEL Braided lines mysteryjimbo SV Talk, Tuning & Tweaking 8 10-02-05 10:20 PM
Braided Lines 454697819 SV Talk, Tuning & Tweaking 14 08-01-05 03:37 PM
