Old 30-04-15, 07:52 AM   #1
kieron_67
Default Cranking Battery Voltage
Hi Guys
Been having trouble with starting my 02 curvy,
the battery was fully charged using a trickle charger and started fine, wait a few hours and the engine is turning over but not starting and eventually the battery dies.
the battery voltage is around 11.8V with the bike off, as soon as i try to start the bike this drops down to around 4ish volts, letting off the start button the battery jumps back up to 11.8V.
Does this indicate a knackered battery or should i check something else?
Thanks guys
Old 30-04-15, 08:45 AM   #2
ophic
ophic's Avatar
Default Re: Cranking Battery Voltage
No load voltage should be 13-odd volts, so I'd say it's time for a new one. How old is it? Has it been fully discharged many times or left in a discharged state for a long period?
Silver SV650SK3, Fuel exhaust
Old 30-04-15, 08:50 AM   #3
kieron_67
Not too sure on the age of the battery, it was on when i brought it.
The bike was left stood with no charger for around 4 or 5 months before i brought it. the battery was completely flat, not even trying to turn over at this point, i charged it and left it on charge using an optimate and all seemed to be ok, i have been using it for the last 1-2 months.
last week i used it at night, the next morning wouldn't start. its been charged and started but after a few hours nothing.
Old 30-04-15, 08:59 AM   #4
Geodude
Geodude's Avatar
If you've got or can borrow a multimeter follow the link in my sig, its so easy to follow even i can do it
What should a good battery voltage be? SVspeedr SV Talk, Tuning & Tweaking 62 22-08-16 05:27 PM
Battery voltage help Geodude SV Talk, Tuning & Tweaking 44 15-05-13 05:48 PM
Battery voltage question. JonGeorge SV Talk, Tuning & Tweaking 1 30-09-12 03:43 PM
Motorcycle Battery Voltage Monitor Lucas SV Talk, Tuning & Tweaking 21 27-02-10 08:32 PM
