Old 09-08-17, 08:51 PM   #1
quik_d
Default K3-k5 GSXR shock
Gsxr1000 shock, fitted to my bike when I bought it but removed as I'm 'big boned' and got a stiffer shock.
Fits the pointy SV with some small modification to the battery box which is easy enough to do.
Works perfectly, all the adjusters are free moving. It has preload, compression and rebound
Pictures here :
https://imgur.com/gallery/79VsE
£50 plus postage or collection from Farnborough, Hampshire
Old 09-08-17, 10:14 PM   #2
DomP
Default Re: K3-k5 GSXR shock
Tempted, what weight rider is it sprung for do you know?
Sent from my SM-G903F using Tapatalk
Black 2010 SV650S Fully faired
White 2011 YZF R125 sold
DomP is offline   Reply With Quote
Old 09-08-17, 10:34 PM   #3
quik_d
Looking at the google docs spreadsheet of SV compatible shocks i believe the spring is 8.1kg/mm and the standard spring is 7.7 so it's a bit stiffer than standard.
Crucially it gives you better control over compression and rebound rather than just preload.
I'm 15 stone and you can see from the pictures I had it wound down quite far in order to get a decent sag setting hence why I swapped it out, but based on this it would be suitable for a range of weights and I would reckon it's sweet spot would be between 11 and 14 stone.
GSXR shock - again. hornby SV Talk, Tuning & Tweaking 1 15-06-10 06:18 PM
Which GSXR shock (again.....) Miles SV Talk, Tuning & Tweaking 73 17-12-08 12:31 PM
K5 gsxr thou shock going onto k5 pointy - will I need the lower gsxr shock bolt? Paul the 6th SV Talk, Tuning & Tweaking 37 31-10-08 12:26 AM
K4 GSXR 600 Shock into a K1? mattyL Bikes - Talk & Issues 5 18-05-07 05:48 PM
For sale GSXR 750 K5 Shock (SV 650 K3 on shock upgrade) alien19779 For Sale - SV's and SV related items 0 28-03-06 01:16 PM
