Old 09-05-20, 11:20 AM   #1
PotatoSV
Default Idle rev adjustment
I have a SV650S from 2003 and I want to adjust the idle revs and the amount of fuel the engine receives, what I want to get in the result is the bike moving by itself if I put it in 1st gear and dont throttle at all. How do I do this and what do I need to adjust, thanks in advance.
Sent from my SM-G975F using Tapatalk
Old 10-05-20, 09:11 AM   #2
Craig380
Default Re: Idle rev adjustment
Assuming your bike is a K3 fuel-injected model, and not a carbed model that was sold in 2003, the clutch switch on the injected bikes changes the injector timing and richens the mixture when the clutch lever is pulled, to help avoid the engine stalling on deceleration.
If your hot idle rpm is set as it should be (1,300rpm) then if you're gentle with the clutch you'll be able to pull away in 1st gear without touching the throttle.
Old 10-05-20, 09:27 AM   #3
PotatoSV
Thank you very much I'll try increasing it and check the results .
Old 11-05-20, 07:29 AM   #4
Craig380
The factory workshop manual actually specifies the idle rpm as 1,300 +/- 100rpm. So up to 1,400rpm is acceptable.
Frequency of idle adjustment? Pointy. Ginja_Joe SV Talk, Tuning & Tweaking 8 22-01-13 11:44 AM
Fast Idle Adjustment, Pointy. capitanscott SV Talk, Tuning & Tweaking 9 16-11-10 06:20 PM
Idle Adjustment danf1234 SV Talk, Tuning & Tweaking 4 25-06-10 12:46 PM
TL1000 Idle speed adjustment....?? chipnix SV Talk, Tuning & Tweaking 4 04-09-07 05:36 PM
