Old 21-09-24, 12:10 PM   #1
Ketharrow
Junior Member
Default Rebuilding/overhauling my gen1
Good evening everyone, i hope i find you all well! 🙂
Wanted to ask for some opinion/advice and maybe get pointed towards the right direction.
It is regarding the cylinder barrels.
I'm rebuilding my gen1 and with the cylinder's measurements I've taken so far it looks like the barrels are neither round or cylindrical any more and in some parts of it out of the manual's given limits.
There are a couple of vertical scratches but not deep. I've read that busa pistons are a common swap, needing a bit of honing at the same time to compensate for the piston to barrel clearance specs. The next option if i want to keep stock bore is the Gladius' cylinders if they are compatible with the rest of the gen1 engine block(any advantage of the upgraded plated cylinder sleeves(?)). Another option is reboring the existing ones to 83mm which in that case i don't know if it'd also need stronger conrods-crank(?)
Also i have been thinking of trying to get the sleeves out and have new made and fitted. Has anyone had any experience going down that road?
If anyone has any info to share please do so.
Any help is more than appreciated!!🙂
Ketharrow is offline   Reply With Quote
Old 21-09-24, 08:21 PM   #2
admin
John T
admin's Avatar
Default Re: Rebuilding/overhauling my gen1
I can't offer any real advice on this but I have heard that busa pistons do fit. It might be worth looking at James Holland Racing website. James knows SV's inside out and developed the original 750 conversion.
https://www.jhsracing.co.uk/
Old 21-09-24, 09:27 PM   #3
garynortheast
garynortheast's Avatar
There's a photo thread here about Haybusa pistons. Not sure which model of SV it refers to though.
**Edit** Just looked and it's for a Pointy.
Blue Curvy S with over 110,000 miles and still going strong.
Crash.NET - Lorenzo: I will put all my efforts into overhauling Rossi NewsBot News 0 14-10-15 09:00 AM
Rebuilding SV after blow-up PhilCBR SV Talk, Tuning & Tweaking 14 23-04-10 12:37 PM
Rebuilding the SV fighter. Grinch SV Talk, Tuning & Tweaking 34 27-08-09 05:44 PM
Rebuilding calipers? irl_dar SV Talk, Tuning & Tweaking 54 06-03-09 10:33 PM
rebuilding SVS, do I have a choice of motor? dizzzzz SV Talk, Tuning & Tweaking 1 14-01-07 02:38 PM
