Old 24-05-25, 09:22 PM   #1
GDBD59
Default Clutch replacement
My partner's curvy needs a new clutch.
I've only worked on a dry clutch before.
I watched a vid on youtube, the guy mentions a gasket, - found that on ebay, - does it need a sealant?
I assume (hope) it'll only be the friction plates that'll need replacing...?
Cheapest place to get them? EDIT - : I see plenty mentions of clutch plates post-2003, - £14 from M & P. But any listing mentioning the curvy K1 is more expensive. Is the early one's different?
Coolant.....what's in them? I have concentrated pink.
GDBD59 is offline   Reply With Quote
Old 25-05-25, 08:32 AM   #2
Default Re: Clutch replacement
Before you go changing clutch plates check the lifter mechanism worm drive as its a common fault of clutch problems.
Old 25-05-25, 09:01 AM   #3
Craig380
It'll be worth checking the steel plates for any signs of rusting or 'blueing' from heat / slipping. The steels must also all be flat, or the clutch will drag: lay each one on a sheet of glass to check.
For what it's worth I would fit new springs too, as they are dirt cheap and they do lose their springiness over time.
Old 25-05-25, 11:52 AM   #4
GDBD59
Thanks for the replies chaps. I've realised the Curvy has a seperate clutch cover, so if it has to come off for plate inspection it's simpler than the SK2.
@Bibio, the bike has only done 17k miles, so I'd be surprised if the clutch has worn out, so you could be right re the worm drive,- certainly worth checking first. What am I looking for?
Old 25-05-25, 12:04 PM   #5
GDBD59
And a specific post.......are the Gen1 & later clutches really different? I'd be surprised if the clutch plates & basket are not used in other Suzuki's never mind the other SV's.....????????????
Old 25-05-25, 12:13 PM   #6
Craig380
You can try checking the part numbers for Gen 1 vs later bikes, this site is pretty good for that:
https://www.suzukiparts.co.uk/shop/o...vehicle_id=110
Old 25-05-25, 01:28 PM   #7
GDBD59
Thumbs up Re: Clutch replacement
Old 26-05-25, 09:08 PM   #8
GDBD59
I've seen an old post re bearings falling out, but not much else. Anything to look for on the unit, or need taken off & split?
The bike has only done 17k so I wouldn't expect the clutch to be worn out.
Using the SV's worm drive part number brings up numerous other bikes, -does this look similar? https://www.ebay.co.uk/itm/205446532804?ul_noapp=true
Old 27-05-25, 08:15 AM   #9
glang
Whats the symptoms as difficult to see how you can finish off an SV clutch in 17k! If the worm drive worn or sticking plates Id expect poor gear changes but not slipping....
Old 27-05-25, 09:29 AM   #10
GDBD59
Agree. The bike has been hardly used in the past two years. I changed the worn cable on it. Somebody else didn't think it was set-up properly. I don't have access to the bike, but the gear change was getting very clunky, becoming very difficult to get neutral & it sounds like there's drag now.
She took it for an MOT & the tester said 'needing new clutch'. Since making the initial post, I've remembered the above info. I remember adjusting the screw on the worm drive before, following a video I think.
So some info on checking the worm drive, - it'll be more convenient if she can check it herself.
Clutch push rod replacement? John D SV Talk, Tuning & Tweaking 5 20-10-12 11:34 AM
Where to buy replacement clutch cable? lazymanc SV Talk, Tuning & Tweaking 10 23-04-12 07:56 PM
Clutch Lever Replacement bubbs1983 SV Talk, Tuning & Tweaking 4 27-05-10 09:33 PM
Clutch lever replacement stophel SV Talk, Tuning & Tweaking 1 23-11-09 12:29 PM
Clutch Cable replacement. dmracing SV Talk, Tuning & Tweaking 1 21-10-07 11:45 AM
