Old 10-10-04, 11:31 PM   #1
SV-Sexy-virgin?
Default wheel polishing
all our bikes are damn fly bitchin peices of kit correct??
so why are the wheels that colour ?
has any one polished there rims without the use of nitromorse (bad experience ended up with 1 black 1 white wheel didnt have time to paint both same colour only had black paint left !!) and this is sexy appart from the colour difference http://www.sv1000.zyns.com/forums/at...chmentid=11811
*bing bong* This has been a public service announcement for talkcompletebull**** air ways thankyou and enjoy your flight
Old 11-10-04, 09:01 PM   #2
Dan_SV
I polished mine up with an angle grinder. Balance seems a bit off mind-but a reasonable finish.
If you want to have shiny wheels- set a day for each one- as you have to take them out, disks off, tyres off, then 180 grit the rim (dont bother with the whole lot-the rough finish on the spokes would take years to do). Rub down to the alloy-using the inner centre as a mark to stop-follow it religiously or the effect will be ****e. Then rub down with 320, then 800 wet. Then its onto a polishing wheel or out with the solvol. I did mine with the polishing wheel. Then Re-assemble.
The rear will take slightly longer than the front, I think mine took around 6 hours each-but the mirror finish looks grand.
Why not wait till you are having your tyres replaced- to save time.
Dan Shiny Wheels
Old 11-10-04, 09:18 PM   #3
I'm going to want mine powdercoated later this year, and that's going to be a laugh... Take wheels off bike. Take off all nonessential parts. Take wheels to bike dealer to take off tyres. Take wheels to powdercoaters. Get wheels back from powdercoaters. Go back to dealers and get tyres put back on and wheels balanced. Put bits back onto wheels. Put wheels back onto bike.
Lots of bus journeys ccarrying 2 bike wheels there But my Roadtecs will only be about halfway through their life, and i can't find a coaters that'll fit and remove tyres near me
Old 11-10-04, 11:48 PM   #4
jonboy
Indeed, tis a problem. I'd like mine done too but don't fancy all the aggro and also being without my bike for a good week or so.
Old 12-10-04, 05:23 AM   #5
DeeJay
But Greg, that would give you another excuse to clean it!!
Old 12-10-04, 05:33 PM   #6
What we need is a set of communal wheels
Old 12-10-04, 09:28 PM   #7
Dan_SV
Buy a set of decent tyre levers- some tyre soap, and some rim protectors and do it yourself. Its tricky, and you will struggle if your a weed-but money can be saved. Balancing is a bit more tricky, but can also be done manually. However its too tricky to explain here- (or im tired and can't be arsed)
Old 12-10-04, 11:19 PM   #8
It's not really money, the price of fitting and balancing on loose wheels is low enough that for me, it's worth it... It's all the faffing around
Old 13-10-04, 08:08 AM   #9
Stig
dunno what all the fuss is about
I use pledge and a duster to polish my wheels, and I have always found that this method is the best and easiest.
Jeez guys, don't you know that using grinding and wet and dry will take all the paint off
tsk tsk you should all know better than this
Polishing my can...... davidimurray SV Talk, Tuning & Tweaking 14 26-09-07 03:22 PM
Polishing alex.j SV Talk, Tuning & Tweaking 7 16-02-06 02:03 PM
Polishing GSXR Carlos SV Talk, Tuning & Tweaking 0 12-06-05 02:19 PM
Polishing Wheel Rims rob13 SV Talk, Tuning & Tweaking 2 05-04-05 11:50 PM
Polishing pencil shavings SV Talk, Tuning & Tweaking 8 10-01-05 11:59 PM
