Old 28-01-05, 11:19 AM   #1
TSM
The Sick Man
TSM's Avatar
Default Datatool 3 seat switch
Has anyone had any problems with the switch on the rear seat?
Sometimes i forget to switch off the alarm on the rear seat and remove it, but the alarm does not always go off.
If i then press it it does go off.
Any ideas.
Probably a faulty sensor or that the system did not even realise that the seat was on in the first place when the system armed and was still waiting for it to put on.
Have to say i dont think it happens if i use the standard seat, only with the cover. I know the underneat is diffrent.
Old 28-01-05, 11:50 AM   #2
Mogs
I've not had any problems with it, but I'm always setting it off that way.
It's probably because the cowl is shaped differently, you could try packing it out so the shape is similar to the underside of the standard seat, thus depressing the switch.
Datatool S4 Alarm COLZO Bikes - Talk & Issues 3 13-03-09 12:40 PM
datatool alarms kwak zzr Bikes - Talk & Issues 29 13-02-09 11:41 PM
Help! Plz.. Datatool keeny90 Bikes - Talk & Issues 18 03-08-08 09:15 PM
Datatool S4 RED, has anyone got one fitted? Lakes_Puma SV Talk, Tuning & Tweaking 5 10-08-07 10:11 AM
Datatool 3 alarm help ... sprocket SV Talk, Tuning & Tweaking 20 29-11-05 05:01 PM
