#11 |
Got the full set of Goodridge lines on today.
Swapped out the front pads for EBC HH compund C. Didn't try to fit the new rear pads. Changed the DOT4. All set and ready to go. Bleeding wasn't as bad as I thought it might be. Folloed the Haynes manual and used a syringe to pull the fluid through on the bleed nipple. Not too bad, worst part was bleeding the front master cylinder. Took a little while to get all the air out. Front calipers were pretty straight forward to bleed too. Thanks for all your replied folks. Cheers |
Rear brake caliper pin | twopots | SV Talk, Tuning & Tweaking | 14 | 22-12-08 06:48 PM |
Where can I buy SS Rear Brake Caliper Pin ? | leegriffiths128 | SV Talk, Tuning & Tweaking | 4 | 22-08-08 02:19 PM |
Cleaning all around the rear wheel / swingarm / rear brake caliper | Camel | SV Talk, Tuning & Tweaking | 12 | 28-04-08 02:00 PM |
Rear brake caliper | madderdog | SV Talk, Tuning & Tweaking | 9 | 15-12-07 01:30 PM |
Rear Brake Caliper! | Phantomtek | Stuff Wanted | 5 | 07-07-07 03:17 PM |
