Old 02-09-08, 08:35 PM   #11
Alpinestarhero
Default Re: Akrapovic on an 08 sensor issue query
FI = Fuel Injection
Old 02-09-08, 08:42 PM   #12
Griffo
Ok well i'll see what Akrapovic say, and JHS I'm getting in touch with too. But it looks like I need to find a place to pop a hole and stick a thread. But then Mr. Dave worries me, if I molest it, put the thing in and still errors... well. I might just end the world instead, or punch Suzuki in the face. How rude!
Old 02-09-08, 08:43 PM   #13
Originally Posted by TSM View Post
there is a reason the sensor is there, the SV is now a closed loop fuel system, the sensor compensates fueling on the engine, it would be probably best to get the nut wealded onto the pipework and fitted, as its k8 its still under warranty and keep running it on FI your warranty is possably up the spout
Isn't the warranty going to be foobarb'd anyway sine he just put a new system on it?
Old 02-09-08, 10:36 PM   #14
Griffo
It's Suzuki doing the exhaust... ?
Old 02-09-08, 10:37 PM   #15
svtomo
closed loop systems sort themselves out usually.
the lambda sensor detects the prcentage of oxygen in the exhaust gas and the ecu constantly changes the fueling.the fuel air mix is always changing from rich to lean (within reason) and so as long as the gases pass through the sensor it should be fine id have thought.
im sure il be corrected if wrong but iv fitted loads of performance exhausts ont cars and not had a problem, dont see why or how the system should be different on a bike.
Old 02-09-08, 10:53 PM   #16
lukemillar
I thought closed loop fuelling only applied at small throttle openings/rpm so smooth out the fuelling in those areas? Above that the ECU just reads the map? I know it is a similar case with fitting a full system to the 675, but there are options to disable the 02 sensor when applying the map. If you are fitting a full system, then you would need a remap, so maybe talk to your dyno guy and see if there is anyway to disable the 02 sensor in the ECU
Old 02-09-08, 11:27 PM   #17
i have a full mivv twin high level on mine and its a k8 3 weeks old... i fitted myself and put the lambda sensor back in (there was a hole with a bung in for it)... no problems what so ever .. in fact i'm getting 65 miles a gallon ...
awsum sound .. it dont growlll it barks.. if you know what i mean.
Old 03-09-08, 08:27 AM   #18
Griffo
Right then! I've been stressing over this all the way in. So it seems that I just need to find a place to cut a hole and put a thread in.
Old 03-09-08, 08:44 AM   #19
jambo
jambo's Avatar
Have you talked to Akropovic yet? You're about to have someone from outside their company cut a hole in one of their exhausts and weld a nut to it. It's not that there's a problem there, but it's not going to be their official 2008 policy is it? They may not be aware of the issue on the 2008 bikes yet.
Jambo
Old 03-09-08, 10:28 AM   #20
Griffo
Hey Jambon,
Right well I've talked to the guy at JHS Racing today, and he'd had a call from Akrapovic regarding my issue too! It seems nobody was really aware about the changes, though JHS guy has tried to get around it, he tells me that the diameter of the pipe on the Akra is too small to fit the lambda in there in the right place or whatnot.
The only system he has that they've got working on a k8 is this M4 race system, though that's about as road legal as a blind goose sadly. So I'm going to stick with the standard exhaust, and just moan about "that's what I get for buying a new bike" etc. for the next 6 years or so.
Oh well!
Akrapovic say they don't support the k8 at the moment In fact they said only up to k6.
Akrapovic full system query? Brettus SV Talk, Tuning & Tweaking 6 12-10-08 01:45 PM
Speed sensor rotor issue - images dclifford SV Talk, Tuning & Tweaking 19 29-09-07 06:38 PM
Akrapovic phil24_7 Exhausts 0 10-02-07 12:05 AM
Akrapovic noisie For Sale - SV's and SV related items 15 12-09-06 03:37 PM
SV650SK2 speedo sensor resistance query mlavender SV Talk, Tuning & Tweaking 0 14-06-05 08:10 PM
