Old 29-09-08, 10:17 AM   #11
Heed
Default Re: which lube?
PJ1 is good. I use that or renthal stuff. I keep a tiny can of Castrol chain wax under the seat just in case the chain needs lubing on a long ride out too.
Old 29-09-08, 11:40 AM   #12
Jdubya
I use either the Wurth dry lube as stated by Fizz or the Profi dry lube which can be pur-chased at your local, and very friendly Hein Gericke store. Both work an absolute treat.
HTH
Old 29-09-08, 11:45 AM   #13
Dangerous Dave
Originally Posted by krhall View Post
I had a scott oiler on the SV and it worked a treat, but there is nowhere to mount it on the new ride.
You do not have to mount the reservoir under the set. With the underseat pipe bikes I have fitted scottoilers to in the past I have placed them either on the side behind the left fairing or under the piece of fairing under the handle bars. You may need a longer piece of tubing though.
How often do you apply it DD?
I'm a bit sad when it comes to bike maintance, the chains get looked at weekly at a minimum and usually cleaned and oiled.
Hows the recovery fella?
Good, gonna get on the bike this afternoon (650).
Old 29-09-08, 12:32 PM   #14
I like the Holts green snot. It may fling a lot off but it seems to keep it nicely lubed at the same time. I gave up with the chain wax stuff, that was horrid.
I'm a bit sad when it comes to keeping the chain clean and lubed. every time I clean the bike I clean the chain and relube too...which is a lot. It doesn't take 2 minutes to clean the fling off your wheel with some WD40 and a cloth.
If you keep up the maintenance of the chain, you very rarely have to adjust it, and it lasts longer
Old 29-09-08, 12:37 PM   #15
krhall
What's the best way to clean the chain then?
Old 29-09-08, 12:39 PM   #16
parrafin or WD40 and a cloth. Make sure you wear rubber gloves cause you get mucky
Old 29-09-08, 06:11 PM   #17
Dangerous Dave
+ 1, the more you do it the easier it is to clean the next time, and the next, and the next...
Problem is you end up as sad as me, one day you too will strip the bike down just for a clean.
Old 29-09-08, 06:29 PM   #18
Bluepete
Bluepete's Avatar
PDL for me too. Top stuff, zero fling, and doesn't make the chain look dirty either.
Top tip for cleaning gunk off wheels; Mr Sheen! Honest, works a treat.
Old 29-09-08, 06:34 PM   #19
My other half told me that earlier as i was posting...I told him I didn't believe him....lolshhhhh don't tell him someone else recommended it.
Old 29-09-08, 06:50 PM   #20
Wurth Dry Lube. We use it on Liz's Duke as it doesnt have a Scotoiler. Doenst fling hardly at all. Give it a try.
Just remember to give the can a good shake before you spray it on the chain.
ive just started using this i must say its fab no fling at all only thing is it doesn't seem to visually lube as good as the pj1? it must work tho cus it says so on the can
How much lube? (Chain lube!) AndyL SV Talk, Tuning & Tweaking 10 10-01-09 08:04 PM
Do I need to lube up?? DoubleD SV Talk, Tuning & Tweaking 2 12-06-08 10:52 AM
Wax or Lube?? Morpheus Bikes - Talk & Issues 26 18-03-05 06:55 PM
What lube do you use? chutz SV Talk, Tuning & Tweaking 26 09-03-04 01:37 PM
Wax or Lube?? chewy22 SV Talk, Tuning & Tweaking 23 04-01-70 03:38 AM
