Old 03-12-08, 10:03 PM   #11
Lozzo
Default Re: Removing ignition barrel (not on an SV)
Isn't the ignition switch bolted to the top yoke? If so you don't have to strip the whole front end down, you take the yoke off with the ignition switch still attached and remove the switch on the bench
Old 03-12-08, 10:09 PM   #12
sauluk
Will check as I'm not sure, picking up new ignition tomorrow hopefully.
Old 03-12-08, 10:50 PM   #13
Lozzo
I'm pretty sure that the igniton switch on a KMX is screwed to the top yoke from underneath.
Old 04-12-08, 08:19 PM   #14
sauluk
It is, I can't get the top yoke off because the screws won't budge whatsoever. Will have to get some more effective tools, managed to get 1 of 4 loose but the others just started to grind my tools apart.
Old 06-12-08, 12:28 PM   #15
sauluk
All done, managed to remove handlebars and yoke and got ignition free once it was all off. Only took a couple of determined hours and 3 trips to the tool shop! New ignition should be here on monday and i'll be able to put it back together!
Old 06-12-08, 01:30 PM   #16
Lozzo
Good man, hope it all fits up ok. Getting the yoke off that way is much easier than stripping the complete front end down.
Old 06-12-08, 02:51 PM   #17
sauluk
Definitely, once I got an allen bolt the right size for the ratchet to get the handle bars off it was a cinch. Managed to get the security bolt out by wedging something against it and gradually twisting it out. Definitely using standard bolts to put it back in!
Ignition barrel sticking gedcarney SV Talk, Tuning & Tweaking 8 15-02-09 10:09 AM
Knackered ignition key barrel ? stewie SV Talk, Tuning & Tweaking 15 15-01-08 05:52 PM
Ignition Barrel Help! krhall Bikes - Talk & Issues 7 19-02-07 11:13 PM
Ignition Barrel BILLY SV Talk, Tuning & Tweaking 12 24-08-06 09:02 PM
Ignition barrel for a K2 Mervin Stuff Wanted 0 03-01-06 04:29 PM
